It’s there… Check capitalization and spelling, then check to be sure that all the pairs of braces in the functions match up. If you can’t get yours to work, compare it to:
// Radial rainbow for 2D displays
// initial circle/rainbow code by @zranger1
// modified for sound by @scruffynerf
export var speed = 0.5
export var direction = 1
export var size = 100
export var spin = 1
export var spincycle = 0
export var spincyclearray = 0
export var frequencyData
export var angle
// UI sliders
// higher is faster
export function sliderSpeed(v) {
speed = 1-v;
// left = inward, right = outward
export function sliderDirection(v) {
direction = (v < 0.5) ? 1 : -1;
// sizing
export function sliderSize(v) {
size = 200*v
// spin
export function sliderSpin(v) {
spin = v
// pythagorean distance from center of display. Pixelblaze
// provides normalized x,y coords, so center is always going
// to be (0.5,0.5) regardless of real world display dimensions
function getRadius(x, y) {
x -= 0.5; y -= 0.5;
return sqrt(x*x + y*y)*2;
// pythagorean angle from center of display. Pixelblaze
function getAngle(x, y) {
x -= 0.5; y -= 0.5;
angle = floor(((atan2(y,x)+PI)/4)*32)%32
angle = (angle+spincyclearray)%32;
return angle;
// generate a timer - a sawtooth wave that we can
// use to animate color -- the direction flag makes
// it positive or negative, depending on the UI slider setting
// spin slider controls the spin, currently only one direction
t1 = direction * time(0.08 * speed);
spincycle = (spincycle + spin)%32
spincyclearray = floor(spincycle);
// use radius+angle and timer to color every pixel, if it's loud enough
radius = getRadius(x, y);
bri = (radius <= frequencyData[getAngle(x,y)]*size) ? 1 : 0.3
hsv(t1+radius, 1, bri);
