A modular led light
If you want to make certain you don’t lose it, you can download a copy of the mapping function from http://{your_pixelblaze_ip_here}/pixelmap.txt to save somewhere, and if you’ve got access to Python you can do a full backup (patterns, pixelmap, hardware and expander configs) of all your PBs using this script.
wow! that looks awesome!
it would be cool if the map page had a list like patterns, and you could edit/save and select the active map. just a thought. it would be more useful if you could set which map to use on a per pattern basis, or have code in the pattern to switch maps.
