Nice. Using array iterative functions, instead of the for loop, and moving the RGB call into the function, you can make it even shorter and cleaner. (I’ll do it with 3.19b shortly.)
Additionally:
It seems a huge waste to define 4 values of 256 (position, R,G,B) as a 4 value array, given that PB stores numbers in 16.16 and can compact those 4 numbers into 1 32 bit value, since the function could extract the 4 8bit values easily enough.
Plus in code, you could also write it as 2 0x hex numbers (since we can’t do hex decimals/fractionals directly), which means it’s still slightly human readable, if you know hex color codes. Seems better than the binary option with 32 1s and 0s. Decimal is still more human readable, though, so likely I’ll figure out a clean way to populate the single array.
Yes, for HDR LEDs, you’d want more bits… but for ‘normal’ usage, reducing the size would mean you could store more palettes in far less space (using less variables too)
So I’ll implement this as tightly as I can, in the hopes that @wizard will just adopt the code/method and add a basic palette selection into firmware. (Assuming people want this, of course)
@wizard, any chance of adding lerp() as built in to 3.19?
