Hi all! I’ve been working on this project recently to build some larger neopixel panels out of smaller 8x8 64 LED panels.
This is still a work in progress but has worked great so far. I intend on adding some additional cuts to make it possible to orient the panels in different directions. Also I started on some designs for stand alone tiles for the 8x8 64 LED panels which I think could be neat to use to make modular static pixel art displays.
I’m not quite ready to put it up on Thingiverse/Prusa’s repositories but if you want to give it a try here’s a temporary link to the model. This was designed to work with CJMCU-8x8 LED panels so fitting it to other models might not work.
