# Input needed: functions wishlist
**URL:** <https://forum.electromage.com/t/input-needed-functions-wishlist/806>\
**Category:** Feature Ideas + Requests\
**Created:** [December 9, 2020, 10:20pm UTC](https://forum.electromage.com/t/input-needed-functions-wishlist/806 "2020-12-09T22:20:32Z")\
**Showing post:** 25
**Author:** ![Irwin](https://forum.electromage.com/user_avatar/forum.electromage.com/irwin/32/2228_2.png) [@Irwin](https://forum.electromage.com/u/Irwin)\
**Post date:** [December 12, 2020, 7:57am UTC](https://forum.electromage.com/t/input-needed-functions-wishlist/806/25 "2020-12-12T07:57:20Z")
Ok, here’s one from left field…
A function that uses the accelerometer to determine the rotational position of a wheel, such as on a bicycle. The PB w/sensor board would be mounted near the center hub with the X and Y axes pointing out toward the rim. The Z axis would be parallel with the axle and would not be part of the equation.
One caveat: since the accelerometer could not be mounted in the exact center of the wheel, there would be some extra force added to both X and Y when the wheel is spinning, which perhaps could be cancelled out mathematically.
The function could return a value between 0 and 1 to represent the angular position of the wheel.
Opinions welcome!
_[View the full topic](https://forum.electromage.com/t/input-needed-functions-wishlist/806)._
