@lnjustin, since your setup is unique, you’re going to have to experiment a little to get the best look.
I think @jeff’s “Candles/Flickerers” pattern from the thread linked below would be a good place to start. Once you’ve got the code loaded, an easy mod that gives your ring a nice flicker all the way around is this:
- find the line that reads
if (candle % 2 == 0) { hsv(0, 0, 0); return } // Candle every three
(it’s somewhere around line 53)
and comment it out (so it reads)
//if (candle % 2 == 0) { hsv(0, 0, 0); return } // Candle every three
The Sparkfire pattern from the library looks like it might be good for this job with a little tweaking too!
