The newer HD107s spec says 30Mhz data transfer. I don’t know if the hardware of the ESP8266 is even capable of it… but if not what about the coming ESP32 rev? I know someone is going to ask “why?” and the only real answer I have is “Someone made a chip that claims it does 30Mhz, someone needs to make a controller that can do it and test that sucker”
It may need to do some kind of shielded twisted pair to get the signal there… but “details”
Ben could ways put a warning next to the option that says “use may cause unexpected results up to and including creation of a blackhole. Use at ye own risk”
Not sure it will help the frame rate much, but we should hold those manufacturers to their advertisement specs!
