Hello,
i’m trying to animate a ring with grows over time. While everything works almost as expected I’m stuck at preventing the ring to grow too big if i increase the speed.
The higher the speed to bigger the ring and he longer the gap until a new ring forms. I would like to have a new ring starts the moment the current ring isn’t visible anymore, independent from its speed.
Any advice like pointing me into the right direction and let me figure it out is appreciated
// set control variables to whatever you think is the best looking
// default value
var circleThickness = 0.05;
var circleRadius = 0.39;
var circleSpeed = 5;
var minSpeed = 0.5;
var maxSpeed = 10;
t1 = time(.1)
export function sliderThickness(v) {
circleThickness = 0.01 + (0.2*v)
circleSpeed = minSpeed + (maxSpeed*v)
// offsetting coordinate to center
x -= 0.5; y -= 0.5;
//animated circle radius
animCircleRadius = t1 * circleSpeed / 4
if (t1 < 1) {
// calculate radius
r = sqrt(x*x+y*y)
if (abs(r-animCircleRadius) < circleThickness) {
s = 1
v = 1
radians = atan2(y, x)
degrees = radians / PI / 2
h = degrees + t1 * 2
else {
s = h = v = 0
hsv(h, s, v)
You’ve clearly got the right idea. It looks like the problem controlling the size is mainly the result of using 1 as the maximum coordinate value instead of 0.5 (because you shifted the origin to the center with x -= 0.5, y -= 0.5)
Just to give you a few ideas to work with, here’s a simple pattern to draw a smoothed, expanding circle, at whatever speed and thickness you need.
speed = 3;
thickness = 0.075
// move coordinate origin to center of display
translate(-0.5,-0.5)
// create sawtooth waveform with period determined by speed, and
// amplitude range [0,0.5] to match adjusted coordinates
t1 = 0.5 * time(.01 * speed)
// draw smoothed circle
h = t1
s = 1
v = 1.0 - abs(hypot(x,y) - t1) / thickness
hsv(h, s, v)
// default values
var circleSpeed = .5;
var minSpeed = 0.05;
translate(-.5, -.5)
circleSpeed = minSpeed + v
t1 = time(.01 * 1/circleSpeed)
s = 1
v = 1.0 - abs(hypot(x,y) - t1) / circleThickness
hsv(h, s, v)
