Is there an easy way to extend the wire for the indicator LED? I’m printing a weather proof housing and I’d like to have a momentary reset pushbutton (which is straightforward) and an indicator LED on the housing so that I can reset and see what’s going on. Is the only way to solder a very small wire to pin 14?
Thanks!
You’ve probably thought about this already, but I’ve had good results printing semitransparent windows above the light, or making separate 3D printed light pipes that I’ve sealed in with rubber cement.
But to confirm, there’s no large-pad solder access.
