@wizard Hi Wizard… I might have found a bug… I have 8xWS2812 strips on the output expander… all working OK. Then (in attempt to turn a strip ‘off’) I changed the LED types to APA type… strips started flashing…
I switched the Type back to WS2812, but it seems the pixelblaze might be having issues (UI is reporting the CPU is “Stalled” or “Error:undefined”. I’ve tried restarting (power on/off)… removing the output expander/re-adding… but same errors.
example message: “Stalled v3.20 FPS:43.44 Mem:8557 Exp:SB1.0”
This is a V3 running v3.20, with output expander and sensor board.
