Data speed and freezing
What are the uses for the list of data speeds? I’m using the modules for pretty basic stuff, mainly motorcycles and wheel rings. And also, any idea why the patterns freeze for a few seconds while I’m linked to it? Works flawless once I disconnect my phone. TIA
The data speeds can tune the tune the timing of data - often a balance between increasing frame rates and data stability. Usually the defaults will be just fine. If you are getting flickering, different settings can help.
Animation pauses can happen when the page is up and there’s a wifi hiccup while it’s sending preview data back. You can click on the live preview to turn it off, though you need it enabled to generate previews for saving when editing patterns.
