Do you have any advice on what kind of strategies I can employ to debug on the PB? How can I get feedback about what values are in certain variables at certain times?
In this particular case I’m getting an out of bounds exception and I’m not sure why.
Yeah, the exported var watcher. I want to add better debug/trace, there’s a lot that could be done with the editor integration as well.
If I want to “debug” a value at a particular point in a render and/or loop, a conditional set would do it. e.g. to capture some value at index 4:
export var debugVar
// ... stuff ...
if (i == 4)
debugVar = someInterestingValue
Then you can live-edit that constant to see other indexes (or move it to a variable closer to the top)
Or you can make an array to hold all values (assuming free space).
