Fake properties?
In seeing lots of nonPB code that I’d like to adapt, the number one “missing piece” is properties.
So given an object exampleObject, the ability to say
exampleObject.speed = 100
exampleObject.hue = .67
etc
Using arrays, I can fake this.
var exampleObject = array(5) // we can have 5 properties
propSpeed = 0
propHue = 1
Then
 exampleObject[propSpeed] = 100
exampleObject[propHue] = .67
I know @wizard just added array shortcuts
For example
arrayLength(a) ↔️ a.length
So I’m wondering if adding a dot mechanic for fake properties is doable
Ala
exampleObject.propSpeed
IF the engine can see .prop shortcut as the equivalent
Or even
exampleObject.Speed
Either of which become equiv to:
I’m ok with having to fake it but it would be awesome to reduce the shim to a minimal
Setup.
Make sense?
And since an array can contain a function, we can fake classes the exact same way, so this would be a twofer.
exampleObject.Display(x)
which could be
exampleObject[propDisplay] = function myFunction(arg1) {return arg1 * 2}
(I think that’s the right format … I didn’t review the lamba version to refresh my mind)
Ooh or just extend the arrayWhatever behavior?
Cause if I could do:
function arraySpeed(x) {
// My code here
And then exampleObject.Speed would call
arraySpeed(exampleObject)
Maybe that could be enough? Dunno. Still pondering.
