Here is the first 30 faces (cells) of a pentagonal hexecontahedron I’m building. It is resin printed and using WS2801 bullet-style LED strand scraps I had laying around from a different project. It has a lot of similarity to @aaroneous’ pentagonal icositetrahedron
I believe this is either xorcery 3D or cube fire 3d:
Here it is with the Fusion 360 model and the axis test:
I could use some ideas on how to power/control this when it’s closed up. The goals are:
- Battery powered so it’s portable
- Control the patterns somehow. Remote? Button?
Ideally I’d be able to run it on battery power and be portable or plug it in to wall power and be always on. I was thinking that a single USB port or 5V barrel jack would be at at one of the vertices, flush against the surface.
Was also thinking a remote could work for changing patterns/brightness? I could test an IR remote, but is that easily added to the V3?
Thanks!
