I saw a project on here where someone made for their kid a linear strip inside some kind of tubing with cloud fluff at either end so it looked like a ‘rainbow’ between two clouds. But searches for ‘rainbow’, ‘cloud’ etc coming up empty. Anyone remember this? Thanks!
Was it this?
Woah! ya thats the same idea. It was someone on this forum with a simpler version, but this works! enough inspiration I can fill in the gaps. thanks.
haha I’m just realizing you built it. It’s great!
Ugh, your whole page is awesome projects that now I want to make for me or the kid ![]()
Maybe this one, not as fancy as @Sunandmooncouture !
Yes! it was that one. Glad I asked though, cool to see @Sunandmooncouture projects.
I didnt write any build notes but feel free to ask questions
Did you have to reinforce the neon LED strips to keep the arch? On mine the PEX tube is rigid enough and already formed into the curve that I didn’t have to do much of anything but cut and hot glue.
This was zip tied to a pegboard for a temp install but for permenant installs I superglue to neon to acrylic or polycarb sheets
Thanks! It came out nicely. I messed up and purchased a roll of 1/2" PEX tubing and my 1/2" APA102’s wouldn’t fit. So I got two straight sections of 3/4" PEX at Home depot. This required hand-bending then a tension string of fishing line between the ends (hot glued in place) to hold the tension into an arc.
Next Steps:
Find a cool ‘bouncing’ back and forth rainbow pattern
Add external button for toddler to turn on/off
Add button for changing between patterns
Basic BOM:
1M strip APA102 - https://www.sparkfun.com/products/14015 - $17.50
2x LED prigtail connectors - https://www.sparkfun.com/products/14576 - $3
USB power source - 5V/2A Wall wart I had on hand
1x Long USB cable from wall wart - https://www.amazon.com/dp/B013CX6XO8?psc=1&ref=ppx_yo2ov_dt_b_product_details - 7$ (white would have been better)
1x Pixel blaze
1x 3/4” Pex tubing - Home depot - recommend curved (don’t buy straight stuff for curved project…)
Craft Fluff - I asked my mom to give me some. YMMV with this option
Cardboard backing cut out of box on hand - https://opopop.com/
LOTS of hot glue
Popsicle sticks to rigidly hold 5 pixels of distance outside of PEX underneath the clouds
Nice build! I guess I lucked.out that my pex tube was rolled up and had a hard curl, wasn’t straight.
The main pattern I had was a hacked version of KITT
// Want to learn how to code patterns like this?
// This pattern has a YouTube video walkthrough:
// https://www.youtube.com/watch?v=3ugNIZ96UK4
leader = 0
direction = 1
pixels = array(pixelCount)
speed = pixelCount / 800
fade = .0007
var lastLeader = floor(leader)
t1 = time(.1)
if (leader >= pixelCount) {
direction = -direction
leader = pixelCount -1
if (leader < 0) {
leader = 0
pixels[floor(leader)] = 1
// Fill pixels between frames. Added after the video walkthrough was uploaded.
up = lastLeader < leader
for (i = lastLeader; i != floor(leader); up ? i++ : i-- ) pixels[i] = 1
pixels[i] -= delta * fade
pixels[i] = max(0, pixels[i])
v = pixels[index]
v = v*v*v
hsv(index / pixelCount + t1, 1, v)
Then I had one with some lightning in the clouds
endPixels = 14
midPixelCount = pixelCount - endPixels*2
var t1
var p1 = array(pixelCount)
var p2 = array(pixelCount)
t1 = time(.03)
function renderMid(i, x) {
h = (t1 + triangle(x)/2)
s = 1
v = 1
hsv(h, s, v*.5)
function renderStart(i, x) {
p1[i] *= .95
if (p1[i] < .001)
p1[i] = random(5)
hsv(0,0,p1[i] - 1)
function renderEnd(i, x) {
p2[i] *= .95
if (p2[i] < .001)
p2[i] = random(5)
hsv(0,0,p2[i] - 1)
rgb(0,0,0)
if (index < endPixels) {
renderStart(index, index / endPixels);
} else if (index < endPixels + midPixelCount) {
renderMid(index - endPixels, (index - endPixels) / midPixelCount)
renderEnd(index - endPixels - midPixelCount, (index - endPixels - midPixelCount)/endPixels)
If i were going to build this again, i’d probably
- use the original 1/2in already-curved Plex tube
- WS2812s - easier to use and unless you want ultra high refresh rates no need for APA102
- Thinner LED strip to actually fit inside the 1/2in tubes! e.g.
The hardest part about my project was by far the fisihing line to hold the tube under tension for a nice bow shape.
