I’m trying to do something very simple: Add a Speed and Direction slider for a rainbow pattern.
I use this bit to get a 0 or 1 value for direction, and export the var for checking:
export var direction
export function sliderDirection(v) {
direction = floor(v)
When I move the slider, I get 0 or 1 in the Vars Watch, all good. Once I introduce an if statement in the export render function, direction value sticks to 0 no matter where the slider is, and as expected the pattern doesn’t change direction. What am I doing wrong?
Code:
export var speed
speed = ((1-v) / 4) + .002;
t1 = time(speed)
if (direction = 0) {
h = t1 + index/pixelCount
s = 1
v = 1
hsv(h, s, v)}
else {
h = t1 - index/pixelCount
s = 1
v = 1
hsv(h, s, v)
That was it, I used > .75 and now it switches right in the middle of the slider, thanks!
If you have some time, do have a look at my question here: Multisegment pattern - #7 by Petros, I’m having trouble doing the math properly so that the segments scale properly regardless of strip length.
Petros, for this sort of thing, the most efficient way of building the if statment is to go backwards from the last segment. Here’s a working example, based on your code:
( to make a code block, just enclose the code in 3 of the ‘backtick’ marks - the single quote that shares the '~" key on most keyboards. These guys – ```)
// controls won't set values until they're actually touched,
// so you need to initialize all your variables in advance.
var hue1 = 0;
var hue2 = 0.333;
var hue3 = 0.6667;
var saturation1 = saturation2 = saturation3 = 1;
var value1 = value2 = value3 = 0.7;
export var depth1 = depth2 = floor(pixelCount/3);
//Colour Picker 3
export function hsvPickerHue3(h, s, v) {
hue3 = h
saturation3 = s
value3 = v
export var depth1
export function sliderDepth1(v) {
depth1 = floor(v * 100 );
export var depth2
export function sliderDepth2(v) {
depth2 = floor(v * 100 );
if (index >= depth1 + depth2) { // everything after depth2
hue = hue3
saturation = saturation3
value = value3
else if (index >= depth1) { // after depth1
hue = hue2
saturation = saturation2
value = value2;
hsv(hue2, saturation2, value2)
else { // from 0 to end of depth1
hue = hue1
saturation = saturation1
value = value1
hsv(hue, saturation, value)
