Hello:
I would like to use the showNumber() to show the peak (highest) energyAverage value. How can I do this?
Thanks,
Hello:
Thanks,
Here’s one way to do it:
// set up a variable to track the max energy average
var maxEV = -9999; // any very low value will do
// set up your display function to show the current maximum
function showNumberMaxEnergyAverage() {
return maxEV;
// then, in beforeRender, check to see if the energyAverage is higher than
// our saved max. If so, save the new value.
function beforeRender(delta) {
if (energyAverage > maxEV) maxEV = energyAverage;
.... (other beforeRender() code) ...
Thanks. I’ll give this a try.
Thanks @ zranger1. The code works great and with your explanation I understand how to apply the same strategy in similar situations. Cheers.
