Not sure what I did, but my pixelblaze won’t turn on anymore and gets so hot I can’t even touch it. Not sure what happened. One minute it’s running like a top, and the next it’s broken down on the side of the road.
ESD zap maybe? Over voltage? Which part is hot?
I’ll double check when I get home. Pretty sure near the button.
Take pictures too, and show how you was trying to power the board, and what else was plugged in!
Will do! I lights powered with a couple 5v mean well power supplies and powered the pixelblaze by usb.
Did you make sure the LED power supplies and PB USB have a common ground? If not … that could explain the heat!
