PB Friends, @JasonCoon gave me a great tip on using JST XH connectors to quickly add/remove items from a PixelBlaze v3 without limiting boards by soldering on an expansion pack. He’s showing a setup here with 4 pins soldered to the v3:
This seems like a great way to be able to add & remove sensor boards. He’s got a 4 pin JST connector here. It looks like this sacrifices the TX pin. I can’t think of any reason why I’d really use that pin. I suppose it’d be safer to use an 8pin JST connector just in case I needed to break out those other wires, but do you see any downsides to using either the 4 pin or 8 pin JST on my boards?
We do plan some large-ish installations - archways of lights folks can walk under, a field of LED lights that are animated, etc. I want students to be able to be creative for a campus “Festival of Lights” with some outdoor LED fun, but I’m really super-new to all of this so I’m not embarrassed and in fact welcome to be talked through thinking like I’m a n00b.
It looks like the sensor board doesn’t have distance sensor. We use STEMMA-QT Time of Flight sensors (VL53L1X). I’d love to be able to connect those to the PB or Sensor Unit (again I don’t know where to begin to think about this) and receive sensor readings to pump into the animations so things like archways & sculptures could react to proximity. I assume these plans aren’t impacted by the JST choice, but wanted to mention just in case. Thanks!
Regarding the TX pin, if you ever needed it, you could just trim the leg of the JST-XH header back. Then you’d be able to solder a wire or header to it.
