Is it okay to wire it like this or should i be using the next set of holes? I tried soldering the screw terminal through the next lot of holes to make the sandwich and messed up my soldering so it wasnt a stable connection, can i use this set of holes instead?
That’s totally ok! The only downside is it’s less easy to separate or reconfigure.
