Just noticed that GLSL has most of the same limitations as PB for arrays:
We can also use Arrays. Of course they have to be typed and there are twists:
- they have a fixed size
- you can’t push(), pop(), splice() etc. and there is no
lengthproperty- you can’t initialize them immediately with values
- you have to set the values individually
this won’t work:
int values[3] = [0,0,0];but this will:
int values[3]; values[0] = 0; values[1] = 0; values[2] = 0;
Actually the more I read that appendix 4 (which is GLSL from a JS perspective), the more I think adding vectors/etc is the right way to extend PB’s language, as we’re seeing how useful the shaders are for making good stuff in PB.
it’s lines like this
note : in a shader, color values (
R,G,B&A) are normalised, they range from 0 to 1 and not from 0 to 0xFF,
that tell me PB is a natural fit for GLSL. It won’t be 100%, but then PB isn’t a 100% fit for JS either… but if more GLSL-flavored stuff (like vectors) are added, we might hit the point where porting bits is trivial (which as @zranger’s been doing so, it isn’t quite trivial yet)
