I asked back in August last year, and I wanted to rebuild a project using only Pixelblaze parts. But I think I need the resolution 8 g gives, and I may even want to go down to the 4 g range.
Last time I asked, it looked like a new board rev is needed for this to happen, not a software change.
Is this still the case, and are there plans for a board rev that enables this setting?
Hi @paulwb ,
Right, it’s coded in the sensor board firmware. It is possible to reflash the firmware for the sensor board to change it (with an STM32 programmer), but isn’t possible from Pixelblaze itself.
Depending on what you need, a filter might help considerably with any jitter, at the cost of responsiveness.
Hmm. I do have an ST Nucleo board that I never did anything with and might be able to work as a programmer, but getting a whole ST toolchain up and running just to change a single value might be more than I want to do for this project.
I should experiment with a filter and see how that goes. Responsiveness is key for the two programs I’d use it for. Hmm.
An external board like Adafruit’s ADXL345 is ruled out, because I’d need to use an I2C/SPI library to get the data from it, which is not a possibility here. Maybe I can look for accelerometer boards that have analog out.
