Hi all, enthusiastic Pixelblaze user here <3
I’m converting some home-installed art I made a while back from using FadeCandy (RIP) to Pixelblaze (happy to chat more about why/how if there is interest).
I’m using this as an opportunity to try out the Pro Output Expander. I had a lot of luck using the smaller Output Expander in a previous project and I’m running into some behavior that is different from what I expect. Some questions:
- Do all fuses have to be in place, to use any of the outputs?
- Should the green draw LED be lit all the time? The documentation states that “this lights up when the address is set correctly and data is sent for one of it’s outputs.”, but I noticed no matter what address I toggle the jumpers to (my PB’s output expander board is set to channel 0), the light remains green. In fact, even disconnecting the data/clock from the PB->expander does not turn the green light off (see attached picture).
In terms of ruling out issues, I can confirm the Pixelblaze Standard V3 I am using works properly because attaching my LED strips to it directly works fine.
Thanks in advance for any help or advice with troubleshooting.
