Here is the final Lawn of Light in front of the St. Ignatius statue at Boston College. Thanks to all who so kindly offered advice. Mapping was easier than I thought. I had a drone photo taken then fed it to Claude Fable and it came up with a perfect map.
1,560 LEDs Lighting the St. Ignatius Lawn @ Boston College using PixelBlaze
That even spacing really makes the display read as a single surface rather than separate strings. With 1,560 LEDs, did you need to add power injection along the runs, or did you keep each segment short enough that one supply handled it?
