How wide are the LED strips you sell in your store? Specifically, the SK9822 variants?
Thanks!
Thanks!
Hi @alandoak,
It’s about 4mm high, and 14mm wide including the silicone tube. The tube walls are about 1mm thick. The LED strip part itself is very thin and sits on the bottom of this channel, with the LED package taking up most of the internal height (~2mm). Without the tube, the strip is 12mm wide.
There is an end cap on either side that expands the dimensions by 2mm in each direction where the connectors are attached.
