Cleaned up and optimized. In particular the neat thing here is:
function WuLine(pfn, x0, y0, x1, y1, h, s, v) {
… where pfn is a function, and I use two different blending functions in the clock!
// This pattern creates a rectangular framebuffer
// and does its own integer coordinate mapping
// and draws an analog clock
// with sweeping hands
// using Xiaolin Wu's antialiased line algorithm.
var blur = 0
export function sliderMotion_Blur(v) {
blur = v * 0.95
// export var hour, minute, second, hx, hy, mx, my, sx, sy
// Duplicate PixelBlaze 'Mapper' functionality without normalizing
var width = 16
var height = width
var mid = width/2 - 0.5
var midm1 = mid - 1
var midm2 = mid - 2
var hlen = midm2 * 2/3
var coordmap = array(pixelCount)
for (index=0; index<pixelCount; index++) {
x = floor(index / height)
y = index % height
y = x % 2 == 1 ? height - 1 - y : y // I have a zigzag LED matrix
coords = array(2)
coords[0] = x
coords[1] = y
coordmap[index] = coords
// HSV to RGB using global variables
var h, s, v // filled by HSVtoRGB
function HSVtoRGB(h, s, v) {
var i, f, p, q, t;
i = floor(h * 6);
f = h * 6 - i;
p = v * (1 - s);
q = v * (1 - f * s);
t = v * (1 - (1 - f) * s);
im6 = i % 6
if (im6 == 0) {
r = v; g = t; b = p;
} else { if (im6 == 1) {
r = q; g = v; b = p;
} else { if (im6 == 2) {
r = p; g = v; b = t;
} else { if (im6 == 3) {
r = p; g = q; b = v;
} else { if (im6 == 4) {
r = t; g = p; b = v;
} else {if (im6 == 5) {
r = v; g = p; b = q;
// RGB framebuffer
// ... Storage
var Pr = array(width); for (i=0; i<width; i++) Pr[i] = array(height)
var Pg = array(width); for (i=0; i<width; i++) Pg[i] = array(height)
var Pb = array(width); for (i=0; i<width; i++) Pb[i] = array(height)
// ... Render a pixel
// - Only used by WuLine, so we do 'alpha' here to keep WuLine readable
// - Uses max() so overlapping line pixels don't make bright spots
function PixelMax(x,y,a,h,s,v) {
if (x >= 0 && x < width && y >= 0 && y < height) {
HSVtoRGB(h,s,v*a*a*a)
Pr[x][y] = max(Pr[x][y], r)
Pg[x][y] = max(Pg[x][y], g)
Pb[x][y] = max(Pb[x][y], b)
// just attenuate the existing pixel data by a
function PixelMultiply(x,y,a,h,s,v) {
Pr[x][y] = clamp(Pr[x][y] * a, 0, 1)
Pg[x][y] = clamp(Pg[x][y] * a, 0, 1)
Pb[x][y] = clamp(Pb[x][y] * a, 0, 1)
// Xiaolin Wu's antialiased line algorithm
// Adapted from https://gist.github.com/polyamide/3f33cb4dc69e22fbf8b66cee39b78d60
// (replaced utility functions with PixelBlaze built-ins)
if (x0 == x1 && y0 == y1) return
steep = abs(y1 - y0) > abs(x1 - x0);
if (steep) {
tmp = y0; y0 = x0; x0 = tmp;
tmp = y1; y1 = x1; x1 = tmp;
if (x0 > x1) {
tmp = x0; x0 = x1; x1 = tmp;
tmp = y0; y0 = y1; y1 = tmp;
dx = x1 - x0;
dy = y1 - y0;
gradient = dy / dx;
xEnd = round(x0);
yEnd = y0 + gradient * (xEnd - x0);
xGap = 1 - frac(x0 + 0.5);
xPx1 = xEnd;
yPx1 = trunc(yEnd);
if (steep) {
pfn(yPx1, xPx1, 1 - frac(yEnd) * xGap, h, s, v )
pfn(yPx1 + 1, xPx1, frac(yEnd) * xGap, h, s, v )
pfn(xPx1, yPx1, 1 - frac(yEnd) * xGap, h, s, v )
pfn(xPx1, yPx1 + 1, frac(yEnd) * xGap, h, s, v )
intery = yEnd + gradient;
xEnd = round(x1);
yEnd = y1 + gradient * (xEnd - x1);
xGap = frac(x1 + 0.5);
xPx2 = xEnd;
yPx2 = trunc(yEnd);
if (steep) {
pfn(yPx2, xPx2, 1 - frac(yEnd) * xGap, h, s, v )
pfn(yPx2 + 1, xPx2, frac(yEnd) * xGap, h, s, v )
pfn(xPx2, yPx2, 1 - frac(yEnd) * xGap, h, s, v )
pfn(xPx2, yPx2 + 1, frac(yEnd) * xGap, h, s, v )
if (steep) {
for (x = xPx1 + 1; x <= xPx2 - 1; x++) {
pfn(trunc(intery), x, 1 - frac(intery), h, s, v )
pfn(trunc(intery) + 1, x, frac(intery), h, s, v )
intery = intery + gradient;
pfn(x, trunc(intery), 1 - frac(intery), h, s, v )
pfn(x, trunc(intery) + 1, frac(intery), h, s, v )
// Render-related variables persistent between frames
export var lastsecond = -1
export var ms = 0
// Clear (or fade if blur enabled) framebuffer
// and render the current time
for (i=0; i<width; i++) {
for (j=0; j<height; j++) {
Pr[i][j] = blur * Pr[i][j]
Pg[i][j] = blur * Pg[i][j]
Pb[i][j] = blur * Pb[i][j]
// get the time
second = clockSecond()
if (second == lastsecond) {
ms = clamp(ms + delta, 0, 1000)
ms = 0
lastsecond = second
second = (second + ms/1000) % 60
minute = (clockMinute() + second/60) % 60
hour = (clockHour() + minute/60) % 12
hangle = PI * (hour/6)
mangle = PI * (minute/30)
sangle = PI * (second/30)
uangle = PI * (ms/500)
hx = clamp(sin(hangle), -1,1) * hlen
hy = clamp(-cos(hangle),-1,1) * hlen
mx = clamp(sin(mangle), -1,1) * midm2
my = clamp(-cos(mangle),-1,1) * midm2
sx = clamp(sin(sangle), -1,1) * midm1
sy = clamp(-cos(sangle),-1,1) * midm1
su = sin(uangle)
cu = -cos(uangle)
ux = clamp(su, -1,1) * mid
uy = clamp(cu,-1,1) * mid
vx = clamp(su, -1,1) * midm1
vy = clamp(cu,-1,1) * midm1
WuLine(PixelMax, mid, mid, mid + hx, mid + hy, 0, 0, 1)
WuLine(PixelMax, mid, mid, mid + mx, mid + my, 1/3, 0.9, 1)
WuLine(PixelMax, mid, mid, mid + sx, mid + sy, 0, 0.9, 1)
WuLine(PixelMax, mid + vx, mid + vy, mid + ux, mid + uy, 2/3, 2/3, 1/4)
for (h = 0; h < 12; h++) {
ha = PI * (h/6)
sh = sin(ha)
ch = -cos(ha)
x1 = mid + clamp(sh, -1,1) * midm1
y1 = mid + clamp(ch,-1,1) * midm1
x2 = mid + clamp(sh, -1,1) * mid
y2 = mid + clamp(ch,-1,1) * mid
WuLine(PixelMultiply, x1, y1, x2, y2, 1, 1, 1)
// Draw from the framebuffer
coords = coordmap[index]
x = coords[0]
y = coords[1]
rgb(Pr[x][y], Pg[x][y], Pb[x][y])
