The LEDfx devs are making amazing progress in adding new features to their code.
One “in development” bit is adapting PB patterns to work with it. It’s required some new ways of handling things
two problems:
1. converting hsv to rgb is simple enough for a single pixel, but iterating over an entire array would be too slow
i found a vectorised conversion that operates on the entire array, very fast!
2. pixelblaze uses render() function on each pixel, again iterating over the array. too slow in python
i came up with some methods to convert the iterative functions to vectorised ones, again very fast!
The code is in dev, in the Virtual branch on GitHub
Looks like fast pulse among others.
I suspect not all patterns will lend themselves to a “vectorizing” but hopefully this will be a good start.
