So, I managed to get Scrolling Text Marquee running on my V2 with a 16x16 display. Unfortunately, the letters are backwards. At the standard 8x8 setting, the letters were split in the middle and going in opposite directions. How do I fix this?
Mapper Code
function (pixelCount) {
width = 16
var map = []
y = Math.floor(i / width)
x = i % width
map.push([x, y])
return map
2D Scrolling Text Maquee code
Scrolling text marquee 2D
This pattern animates ASCII characters scrolling across an LED matrix.
Demo: https://youtu.be/668eQjiqSRQ
The default settings work well with the $14 8x8 matrix sold here:
https://www.tindie.com/products/electromage/electromage-8x8-led-matrix/
Use the mapper to define how the matrix is wired (for example, zig-zag).
The 8x8 grid above works with the default "Matrix" example on the Mapper tab.
With no map and just a 1D strip, you can use this to light paint text:
https://photos.app.goo.gl/vU2BQsP6V84Zr6Df7
Author: Jeff Vyduna (https://ngnr.org)
Bugfixes: Zeb (https://forum.electromage.com/u/zeb)
// Characters we want to scroll by every second. Try 3 for a matrix, or 30 for
// persistence-of-vision on a strip.
var speed = 3
// Define the message to be scrolled across the display
var messageLength = 12
export var message = array(messageLength) // Exported for setting via webSockets
// " Hello?!?"
message[0] = 32; message[1] = 32; // Leading spaces
message[2] = 72; // H
message[3] = 101; // e
message[4] = 108; // l
message[5] = 108; // l
message[6] = 111; // o
message[7] = 30; message[8] = 33; message[9] = 31 // "?!?"
ASCII Chart
32 48 0 65 A 74 J 83 S 97 a 106 j 115 s
33 ! 49 1 66 B 75 K 84 T 98 b 107 k 116 t
34 " 50 2 67 C 76 L 85 U 99 c 108 l 117 u
35 # 51 3 68 D 77 M 86 V 100 d 109 m 118 v
36 $ 52 4 69 E 78 N 87 W 101 e 110 n 119 w
37 % 53 5 70 F 79 O 88 X 102 f 111 o 120 x
38 & 54 6 71 G 80 P 89 Y 103 g 112 p 121 y
39 ' 55 7 72 H 81 Q 90 Z 104 h 113 q 122 z
40 ( 56 8 73 I 82 R 105 i 114 r
41 ) 57 9
42 * 58 : 91 [ 123 {
43 + 59 ; 92 \ 124 |
44 , 60 < 93 ] 125 }
45 - 61 = 94 ^ 126 ~
46 . 62 > 95 _
47 / 63 ? 96 `
64 @
// Define the font's character set bitmap. See "Font Implementation" below.
var charRows = 16 // Rows in a character. 1 array per row.
var charCols = 16 // Columns in a character. 1 bit per column.
var fontCharCount = 128 // Max characters in the font. Must be a multiple of 4.
var fontBitmap = array(charRows)
for (row = 0; row < charRows; row++) fontBitmap[row] = array(fontCharCount / 4)
// Global 8x8bit array for storing and fetching characters from fontBitmap
var character = array(charRows)
// Define the 2D matrix display. If your matrix is different dimentions, change
// these to match or use a smaller matrixRows to scale your text height to fill.
var matrixRows = 16
var matrixCols = 16
var renderBuffer = array(matrixRows)
for (row = 0; row < matrixRows; row++) renderBuffer[row] = array(matrixCols)
var timer = 0 // Accumulates the ms between each beforeRender()
// Calculate the ms between each left shift of the message across matrix columns
var colShiftPeriod = 1000 / speed / charCols
timer += delta
if (timer > colShiftPeriod) {
timer -= colShiftPeriod
loadNextCol() // Shift and load a new column every colShiftPeriod ms
export var hue, sat // Exported so you can set them over websockets
hue = 0.05; sat = 0.9 // warm white
// y is in world units of 0...1 where (0,0) is the top-left and y is +↓
row = floor(y * matrixRows)
// The column to render is like the row, but physical column 0 (the leftmost)
// starts bufferPointer columns into the renderBuffer.
col = (floor(x * matrixCols) + bufferPointer) % matrixCols
v = renderBuffer[row][col] // 1 or 0
hsv(hue, sat, v)
// On a strip, render the leftmost column. You can use this to light paint in
// long exposure photographs, or render text in POV projects
// Flip such that pixel 0, usually the closest to power, is the bottom of text
index = pixelCount - index - 1
// Mode 1: Use entire strip as a full character line height.
// row = floor(charRows * index/ pixelCount)
// Mode 2: repeat the characters vertically, with linespacing
// If you flicker your eyes left-right, you can see the characters.
// Looks best if you set `speed` above to much faster, like 30 chars/sec
row = index % floor(1.5 * charRows) // 0.5em lineSpacing
if (row > charRows - 1) { hsv(0, 0, 0); return } // blank rows
// Render column 0, which starts bufferPointer columns into the renderBuffer
col = bufferPointer % matrixCols
// The color is added for light painting rainbows, and so that it's still
// somewhat interesting on strips / the default sequencer
hue = wave(time(0.02)) - index / pixelCount
hsv(hue, sat, renderBuffer[row][col])
// When we render the renderBuffer, we start by loading the leftmost column of
// the matrix from the `bufferPointer` column in the renderBuffer.
var bufferPointer = 0
E.g.: 8x8 matrix, rendering halfway through "AC": Right side of A, left of C
renderbuffer[r][c] Renders as:
`bufferPointer` == 4 means leftmost column is here, and wraps around to 3
col = 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7
row = 0 . . . 1 1 . . . 0 1 . . . . . . 1
1 . . 1 1 1 1 . . 1 1 1 . . . . 1 1
2 . 1 1 . . 1 1 . 2 . 1 1 . . 1 1 .
3 . 1 1 . . 1 1 . 3 . 1 1 . . 1 1 .
4 . 1 1 . 1 1 1 . 4 1 1 1 . . 1 1 .
4 . . 1 1 . 1 1 . 4 . 1 1 . . . 1 1
5 . . . 1 . 1 1 . 5 . 1 1 . . . . 1
7 . . . . . . . . 7 . . . . . . . .
This column will be replaced with the next column of "C",
↑ then we'll advance `bufferPointer`
Each element is a 16.16 fixed point number, so you could decide to pack HSV or
RGB info into each byte, but this example is monochrome so each element just
stores a 0 or 1, making rendering as simple as:
if (renderBuffer[row][col]) hsv(0,0,1)
var messageCols = messageLength * charCols // e.g., 12 chars have 96 columns
var messageColPointer = 0 // The next column of the overall message to load
// Load the next column from `message` into `renderBuffer` at `bufferPointer`
function loadNextCol() {
charIndex = message[floor(messageColPointer / charCols)]
fetchCharacter(charIndex) // loads global `character` with ASCII charIndex
colIndex = messageColPointer % charCols
for (row = 0; row < charRows; row++) {
bit = (((character[row] << colIndex) & 0b10000000) == 0b10000000)
renderBuffer[row][bufferPointer] = bit
bufferPointer = (bufferPointer + 1) % matrixCols
messageColPointer = (messageColPointer + 1) % messageCols
Font Implementation
Pixelblaze currently supports up to 64 arrays with 2048 array elements.
To store a character set of 8x8 bit characters, we use 8 arrays,
one for each row.
Four 8-bit maps are packed into each 32 bit array element. This makes the
bitwise code a little hard to follow, but uses memory efficiently. The 8 most
significant bits are referred to as "bank 0"; the next eight bits just left of
the binary point are "bank 1", etc.
Here's the scheme used to store the font bitmap. A period is a zero.
ASCII character A B C D E
`charIndex` 65 66 67 68 69
array element [16] [16] [16] [16] [17]
bank 0 1 2 3 0
fontBitmap[0] ..11.... 111111.. ..1111.. 11111... 1111111.
fontBitmap[1] .1111... .11..11. .11..11. .11.11.. .11...1.
fontBitmap[2] 11..11.. .11..11. 11...... .11..11. .11.1...
fontBitmap[3] 11..11.. .11111.. 11...... .11..11. .1111...
fontBitmap[4] 111111.. .11..11. 11...... .11..11. .11.1...
fontBitmap[5] 11..11.. .11..11. .11..11. .11.11.. .11...1.
fontBitmap[6] 11..11.. 111111.. ..1111.. 11111... 1111111.
fontBitmap[7] ........ ........ ........ ........ ........
charIndex 0..31 (traditionally the ASCII control characters) are left
blank for user-defined custom characters.
Font and character functions
The storeCharacter functions take the character index (< `fontCharCount`) and
8 rows of 8 bits. Each row is a byte representing 8 bits of on/off bitmap data
to become the pixels of a character. Therefore, this implementation is
currently tightly coupled to 8-bit wide characters.
At character index `charIndex`, store 8 bytes of row data specified as
sequential arguments r0-r7. This allows us to easily use the public domain
font specified as comma-delimited hex bytes at:
https://github.com/rene-d/fontino/blob/master/font8x8_ib8x8u.ino
function storeCharacter(charIndex, r0, r1, r2, r3, r4, r5, r6, r7) {
element = floor(charIndex / 4)
bank = charIndex % 4
packByte(0, element, bank, r0)
packByte(1, element, bank, r1)
packByte(2, element, bank, r2)
packByte(3, element, bank, r3)
packByte(4, element, bank, r4)
packByte(5, element, bank, r5)
packByte(6, element, bank, r6)
packByte(7, element, bank, r7)
This alternate style stores the character using the 8 row global array named
`character`. It could be useful for storing sprites after transformations to
create animations.
function storeCharacter2(charIndex) {
for (var row = 0; row < charRows; row++) {
packByte(row, element, bank, character[row])
// Loads the global `character` from the specified charIndex
function fetchCharacter(charIndex) {
character[row] = unpackByte(row, element, bank)
For a given row of a font's pixel data (fontBitmap[row]), there's a
(fontCharCount / 4) element long array that holds 32 bits per array element.
Thinking of each array element as a 4-byte word, the "bank" (0..3) specifies
which set of 8 bits we're storing for a particular character. Characters are
referred to by their charIndex (ASCII number), so:
bank 0 in elements 0, 1, & 2 store the data for characters 0, 4, 8, etc;
Bank 1 in elements 0, 1, & 2 store the data for characters 1, 5, 9, etc.
The method below is used because the bitwise operators only work on
the top 16 bits.
var byteHolder = array(4)
function packByte(row, element, bank, byte) {
original = fontBitmap[row][element]
// Load a 4-element array with the individual bytes in this 32 bit 'word'
for (_bank = 0; _bank < 4; _bank++) {
byteHolder[_bank] = (((original << (_bank * 8)) & 0xFF00) >> 8) & 0xFF
// Override the 8 bits we're trying to store
byteHolder[bank] = byte
// Reassemble the 32 bit 'word'
fontBitmap[row][element] = (byteHolder[0] << 8)
+ byteHolder[1]
+ (byteHolder[2] >> 8)
+ (byteHolder[3] >> 16)
// Inverse of packByte()
function unpackByte(row, element, bank) {
word = fontBitmap[row][element]
if (bank > 1) {
byte = word << (8 * (bank - 1))
} else if (bank == 0) {
byte = word >> 8
byte = word
return byte & 0xFF // Zero out all but the 8 bits left of the binary point
Font Data
Public domain, courtesy of
storeCharacter( 32, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x20 (space)
storeCharacter( 33, 0x30, 0x78, 0x78, 0x30, 0x30, 0x00, 0x30, 0x00) // 0x21 (exclam)
storeCharacter( 34, 0x6c, 0x6c, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x22 (quotedbl)
storeCharacter( 35, 0x6c, 0x6c, 0xfe, 0x6c, 0xfe, 0x6c, 0x6c, 0x00) // 0x23 (numbersign)
storeCharacter( 36, 0x30, 0x7c, 0xc0, 0x78, 0x0c, 0xf8, 0x30, 0x00) // 0x24 (dollar)
storeCharacter( 37, 0x00, 0xc6, 0xcc, 0x18, 0x30, 0x66, 0xc6, 0x00) // 0x25 (percent)
storeCharacter( 38, 0x38, 0x6c, 0x38, 0x76, 0xdc, 0xcc, 0x76, 0x00) // 0x26 (ampersand)
storeCharacter( 39, 0x60, 0x60, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x27 (quotesingle)
storeCharacter( 40, 0x18, 0x30, 0x60, 0x60, 0x60, 0x30, 0x18, 0x00) // 0x28 (parenleft)
storeCharacter( 41, 0x60, 0x30, 0x18, 0x18, 0x18, 0x30, 0x60, 0x00) // 0x29 (parenright)
storeCharacter( 42, 0x00, 0x66, 0x3c, 0xff, 0x3c, 0x66, 0x00, 0x00) // 0x2a (asterisk)
storeCharacter( 43, 0x00, 0x30, 0x30, 0xfc, 0x30, 0x30, 0x00, 0x00) // 0x2b (plus)
storeCharacter( 44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x60) // 0x2c (comma)
storeCharacter( 45, 0x00, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x00, 0x00) // 0x2d (hyphen)
storeCharacter( 46, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00) // 0x2e (period)
storeCharacter( 47, 0x06, 0x0c, 0x18, 0x30, 0x60, 0xc0, 0x80, 0x00) // 0x2f (slash)
storeCharacter( 48, 0x7c, 0xc6, 0xce, 0xde, 0xf6, 0xe6, 0x7c, 0x00) // 0x30 (zero)
storeCharacter( 49, 0x30, 0x70, 0x30, 0x30, 0x30, 0x30, 0xfc, 0x00) // 0x31 (one)
storeCharacter( 50, 0x78, 0xcc, 0x0c, 0x38, 0x60, 0xc4, 0xfc, 0x00) // 0x32 (two)
storeCharacter( 51, 0x78, 0xcc, 0x0c, 0x38, 0x0c, 0xcc, 0x78, 0x00) // 0x33 (three)
storeCharacter( 52, 0x1c, 0x3c, 0x6c, 0xcc, 0xfe, 0x0c, 0x1e, 0x00) // 0x34 (four)
storeCharacter( 53, 0xfc, 0xc0, 0xf8, 0x0c, 0x0c, 0xcc, 0x78, 0x00) // 0x35 (five)
storeCharacter( 54, 0x38, 0x60, 0xc0, 0xf8, 0xcc, 0xcc, 0x78, 0x00) // 0x36 (six)
storeCharacter( 55, 0xfc, 0xcc, 0x0c, 0x18, 0x30, 0x30, 0x30, 0x00) // 0x37 (seven)
storeCharacter( 56, 0x78, 0xcc, 0xcc, 0x78, 0xcc, 0xcc, 0x78, 0x00) // 0x38 (eight)
storeCharacter( 57, 0x78, 0xcc, 0xcc, 0x7c, 0x0c, 0x18, 0x70, 0x00) // 0x39 (nine)
storeCharacter( 58, 0x00, 0x30, 0x30, 0x00, 0x00, 0x30, 0x30, 0x00) // 0x3a (colon)
storeCharacter( 59, 0x00, 0x30, 0x30, 0x00, 0x30, 0x30, 0x60, 0x00) // 0x3b (semicolon)
storeCharacter( 60, 0x18, 0x30, 0x60, 0xc0, 0x60, 0x30, 0x18, 0x00) // 0x3c (less)
storeCharacter( 61, 0x00, 0x00, 0xfc, 0x00, 0x00, 0xfc, 0x00, 0x00) // 0x3d (equal)
storeCharacter( 62, 0x60, 0x30, 0x18, 0x0c, 0x18, 0x30, 0x60, 0x00) // 0x3e (greater)
storeCharacter( 63, 0x78, 0xcc, 0x0c, 0x18, 0x30, 0x00, 0x30, 0x00) // 0x3f (question)
storeCharacter( 64, 0x7c, 0xc6, 0xde, 0xde, 0xde, 0xc0, 0x78, 0x00) // 0x40 (at)
storeCharacter( 65, 0x30, 0x78, 0xcc, 0xcc, 0xfc, 0xcc, 0xcc, 0x00) // 0x41 (A)
storeCharacter( 66, 0xfc, 0x66, 0x66, 0x7c, 0x66, 0x66, 0xfc, 0x00) // 0x42 (B)
storeCharacter( 67, 0x3c, 0x66, 0xc0, 0xc0, 0xc0, 0x66, 0x3c, 0x00) // 0x43 (C)
storeCharacter( 68, 0xf8, 0x6c, 0x66, 0x66, 0x66, 0x6c, 0xf8, 0x00) // 0x44 (D)
storeCharacter( 69, 0xfe, 0x62, 0x68, 0x78, 0x68, 0x62, 0xfe, 0x00) // 0x45 (E)
storeCharacter( 70, 0xfe, 0x62, 0x68, 0x78, 0x68, 0x60, 0xf0, 0x00) // 0x46 (F)
storeCharacter( 71, 0x3c, 0x66, 0xc0, 0xc0, 0xce, 0x66, 0x3e, 0x00) // 0x47 (G)
storeCharacter( 72, 0xcc, 0xcc, 0xcc, 0xfc, 0xcc, 0xcc, 0xcc, 0x00) // 0x48 (H)
storeCharacter( 73, 0x78, 0x30, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x49 (I)
storeCharacter( 74, 0x1e, 0x0c, 0x0c, 0x0c, 0xcc, 0xcc, 0x78, 0x00) // 0x4a (J)
storeCharacter( 75, 0xe6, 0x66, 0x6c, 0x78, 0x6c, 0x66, 0xe6, 0x00) // 0x4b (K)
storeCharacter( 76, 0xf0, 0x60, 0x60, 0x60, 0x62, 0x66, 0xfe, 0x00) // 0x4c (L)
storeCharacter( 77, 0xc6, 0xee, 0xfe, 0xfe, 0xd6, 0xc6, 0xc6, 0x00) // 0x4d (M)
storeCharacter( 78, 0xc6, 0xe6, 0xf6, 0xde, 0xce, 0xc6, 0xc6, 0x00) // 0x4e (N)
storeCharacter( 79, 0x38, 0x6c, 0xc6, 0xc6, 0xc6, 0x6c, 0x38, 0x00) // 0x4f (O)
storeCharacter( 80, 0xfc, 0x66, 0x66, 0x7c, 0x60, 0x60, 0xf0, 0x00) // 0x50 (P)
storeCharacter( 81, 0x78, 0xcc, 0xcc, 0xcc, 0xdc, 0x78, 0x1c, 0x00) // 0x51 (Q)
storeCharacter( 82, 0xfc, 0x66, 0x66, 0x7c, 0x6c, 0x66, 0xe6, 0x00) // 0x52 (R)
storeCharacter( 83, 0x78, 0xcc, 0xe0, 0x70, 0x1c, 0xcc, 0x78, 0x00) // 0x53 (S)
storeCharacter( 84, 0xfc, 0xb4, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x54 (T)
storeCharacter( 85, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xfc, 0x00) // 0x55 (U)
storeCharacter( 86, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x00) // 0x56 (V)
storeCharacter( 87, 0xc6, 0xc6, 0xc6, 0xd6, 0xfe, 0xee, 0xc6, 0x00) // 0x57 (W)
storeCharacter( 88, 0xc6, 0xc6, 0x6c, 0x38, 0x38, 0x6c, 0xc6, 0x00) // 0x58 (X)
storeCharacter( 89, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x30, 0x78, 0x00) // 0x59 (Y)
storeCharacter( 90, 0xfe, 0xc6, 0x8c, 0x18, 0x32, 0x66, 0xfe, 0x00) // 0x5a (Z)
storeCharacter( 91, 0x78, 0x60, 0x60, 0x60, 0x60, 0x60, 0x78, 0x00) // 0x5b (bracketleft)
storeCharacter( 92, 0xc0, 0x60, 0x30, 0x18, 0x0c, 0x06, 0x02, 0x00) // 0x5c (backslash)
storeCharacter( 93, 0x78, 0x18, 0x18, 0x18, 0x18, 0x18, 0x78, 0x00) // 0x5d (bracketright)
storeCharacter( 94, 0x10, 0x38, 0x6c, 0xc6, 0x00, 0x00, 0x00, 0x00) // 0x5e (asciicircum)
storeCharacter( 95, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff) // 0x5f (underscore)
storeCharacter( 96, 0x30, 0x30, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x60 (grave)
storeCharacter( 97, 0x00, 0x00, 0x78, 0x0c, 0x7c, 0xcc, 0x76, 0x00) // 0x61 (a)
storeCharacter( 98, 0xe0, 0x60, 0x60, 0x7c, 0x66, 0x66, 0xdc, 0x00) // 0x62 (b)
storeCharacter( 99, 0x00, 0x00, 0x78, 0xcc, 0xc0, 0xcc, 0x78, 0x00) // 0x63 (c)
storeCharacter(100, 0x1c, 0x0c, 0x0c, 0x7c, 0xcc, 0xcc, 0x76, 0x00) // 0x64 (d)
storeCharacter(101, 0x00, 0x00, 0x78, 0xcc, 0xfc, 0xc0, 0x78, 0x00) // 0x65 (e)
storeCharacter(102, 0x38, 0x6c, 0x60, 0xf0, 0x60, 0x60, 0xf0, 0x00) // 0x66 (f)
storeCharacter(103, 0x00, 0x00, 0x76, 0xcc, 0xcc, 0x7c, 0x0c, 0xf8) // 0x67 (g)
storeCharacter(104, 0xe0, 0x60, 0x6c, 0x76, 0x66, 0x66, 0xe6, 0x00) // 0x68 (h)
storeCharacter(105, 0x30, 0x00, 0x70, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x69 (i)
storeCharacter(106, 0x0c, 0x00, 0x0c, 0x0c, 0x0c, 0xcc, 0xcc, 0x78) // 0x6a (j)
storeCharacter(107, 0xe0, 0x60, 0x66, 0x6c, 0x78, 0x6c, 0xe6, 0x00) // 0x6b (k)
storeCharacter(108, 0x70, 0x30, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x6c (l)
storeCharacter(109, 0x00, 0x00, 0xcc, 0xfe, 0xfe, 0xd6, 0xc6, 0x00) // 0x6d (m)
storeCharacter(110, 0x00, 0x00, 0xf8, 0xcc, 0xcc, 0xcc, 0xcc, 0x00) // 0x6e (n)
storeCharacter(111, 0x00, 0x00, 0x78, 0xcc, 0xcc, 0xcc, 0x78, 0x00) // 0x6f (o)
storeCharacter(112, 0x00, 0x00, 0xdc, 0x66, 0x66, 0x7c, 0x60, 0xf0) // 0x70 (p)
storeCharacter(113, 0x00, 0x00, 0x76, 0xcc, 0xcc, 0x7c, 0x0c, 0x1e) // 0x71 (q)
storeCharacter(114, 0x00, 0x00, 0xdc, 0x76, 0x66, 0x60, 0xf0, 0x00) // 0x72 (r)
storeCharacter(115, 0x00, 0x00, 0x7c, 0xc0, 0x78, 0x0c, 0xf8, 0x00) // 0x73 (s)
storeCharacter(116, 0x10, 0x30, 0x7c, 0x30, 0x30, 0x34, 0x18, 0x00) // 0x74 (t)
storeCharacter(117, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0xcc, 0x76, 0x00) // 0x75 (u)
storeCharacter(118, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x00) // 0x76 (v)
storeCharacter(119, 0x00, 0x00, 0xc6, 0xd6, 0xfe, 0xfe, 0x6c, 0x00) // 0x77 (w)
storeCharacter(120, 0x00, 0x00, 0xc6, 0x6c, 0x38, 0x6c, 0xc6, 0x00) // 0x78 (x)
storeCharacter(121, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0x7c, 0x0c, 0xf8) // 0x79 (y)
storeCharacter(122, 0x00, 0x00, 0xfc, 0x98, 0x30, 0x64, 0xfc, 0x00) // 0x7a (z)
storeCharacter(123, 0x1c, 0x30, 0x30, 0xe0, 0x30, 0x30, 0x1c, 0x00) // 0x7b (braceleft)
storeCharacter(124, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0x00) // 0x7c (bar)
storeCharacter(125, 0xe0, 0x30, 0x30, 0x1c, 0x30, 0x30, 0xe0, 0x00) // 0x7d (braceright)
storeCharacter(126, 0x76, 0xdc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x7e (asciitilde)
// Other user-defined custom characters
// ASCII 63 is the question mark - here's an alternative from the
// Sinclair ZX81 font, stored in custom slot 30
storeCharacter(30,
0b00000000,
0b00111100,
0b01000010,
0b00000100,
0b00001000,
0b00000000,
0b00001000,
0b00000000
// This demonstrates copying the character, altering it, then storing it in the
// next slot. You could use this for programmatic animation.
fetchCharacter(30)
character[7] = 0b00001000
storeCharacter2(31)
In 8x8 mode
In 16x16 mod
e
