Mapping for an upside down Lux Lavalier
I recently got my Lux Lavalier and tried some patterns. I noticed that the scrolling text marqee 2D pattern is working, but the text is upside down. Maybe I put the panel upside down when I build it? I don’t really think this is possible though.
Anyways, I created a map for my “Aussie” Lux Lavalier, so if you have the same problem you can try and use this one instead:
[[115,127],[66,141],[47,164],[41,192],[47,221],[109,255],[87,234],[75,207],[75,179],[93,149],[103,177],[109,208],[126,230],[152,244],[183,250],[215,217],[185,220],[158,213],[135,194],[124,154],[148,168],[176,186],[205,187],[232,177],[255,157],[248,112],[232,137],[209,153],[179,157],[162,133],[198,124],[218,103],[227,76],[226,46],[168,0],[187,25],[196,53],[193,81],[175,107],[142,113],[164,74],[161,45],[146,20],[122,3],[53,20],[83,21],[110,31],[130,52],[138,85],[110,72],[85,54],[57,50],[28,57],[2,74],[0,121],[20,98],[45,84],[74,82],[107,102],[80,110],[48,117],[27,135],[15,162],[11,192]]
I am no expert on this, but i think you can also solve this problem by keeping the same mapping, and simply remplacing “y” in your pattern code by “1-y”.
If you pattern is generated by some code, you can also do it directly in the pattern. Would need to see the code for this though.
