I hooked up my 8x8 hdr matrix last night, and was trying to figure out what the pixel order on them is. After looking at the board, it looks like it’s not zig zag, but right to left or left to right depending on how you rotate it. It would be great to update the page in the store, or add a separate page about how to set these up!
Hi @hex337,
Thanks for letting me know about the lacking docs!
The color order is GRB, and the default matrix example should work as-is (zigzag).
That map’s orientation assumes the first pixel is on the top left, but the “Multiple Panel Matrix” example mapper can rotate those for you if you have them installed in some other way, and can be used for a single matrix too (set zigzag true).
