Also posted to pattern library. The version above uses more features, but is way more complex. This is a cleaned up, basic and simple version, for new folks to learn from.
Multiple SubMaps with multiple patterns v1.0 - by ScruffyNerf
inspired by various code bits by zranger, Jeff Vyduna and Ben Hencke
Very Simple demo version, a truly minimal example (2 ranges, 2 patterns)
There are lot of ways to do what this pattern does without using multiple maps, it's for building on.
Requirements: Matrix with a 2D map
// these functions can take index,x,y and modify a set of globals to use instead
// isInMap is set to true, if the pixel is in this submap
// NewIndex is the "new" index value, if any [NOT USED IN EXAMPLE]
// NewPixelCount is the pixelcount of the new map, if any [NOT USED IN EXAMPLE]
// NewX is the new value of x for that pixel, might be renormalized, might not, still in range of 0..1
// NewY is the new value of y for that pixel, might be renormalized, might not, still in range of 0..1
var isInMap
var NewIndex = 0;
var NewPixelCount = 0;
var NewX,NewY
// These are the map functions it will consider.
// Order matters, it will consider only the FIRST return of true
// This allows overlapping maps, with the first (0) being "on top",
// and potentially this also allows a background/default map (matching none of the submaps listed)
var mapCount = 2 // number of maps+patterns
var maps = array(mapCount)
maps[0] = inmap0
maps[1] = inmap1
// maps[2] = your map functions go here
function inmap0(index, x, y) {
centerx = x - 0.5;
centery = y - 0.5;
// circle from center of matrix
if (centerx * centerx + centery * centery < 0.04) {
isInMap = true;
NewX = centerx;
NewY = centery;
function inmap1(index, x, y) {
if (x < .5 && y < .5) {
isInMap = true;
// if you are learning how this works, I recommend adding a new map first, and experimenting...
// then add a new pattern (You'll want to just copy a pattern for the new map. Map # matches Pattern # for simplicity )
var patterns = array(mapCount)
patterns[0] = pulseBlue
patterns[1] = pulseGreen
// patterns[2] = your pattern function(s) goes here
function pulseBlue(index,x,y){
hsv(.6, 1, wave(time(.02)))
function pulseGreen(index,x,y) {
hsv(.3, 1, wave(time(x*y+.03)))
matched = false;
NewPixelCount = pixelCount;
NewIndex = index;
NewX = x;
NewY = y;
for (var p = 0; p < mapCount; p++) {
isInMap = false;
maps[p](index, x, y);
if (isInMap) {
patterns[p](NewIndex,NewX,NewY);
matched = true; // to avoid turning light off
p = mapCount; // stop the for loop
if (matched == false) {
// no match, no light
hsv(0,0,0)
// just so it'll render in 1D
export function render(index) {
render2D(index, index / pixelCount, 0)
