I need some help with mapping. For the testing I am using 16x16 matrix with next physical layout:
- Index-0 is in the right upper corner;
- Zigzag wiring is Right-to-Left and Top-to-Bottom;
For the mapping testing I am using “Multiple Panel Matrix” from the example (because eventually it will be three 16x16 matrix assembled horizontally into 48x16 matrix) and " Red_Green_XY_2D_Sweep" pattern. On the “preview” pan everything looks as expected (i.e. Green sweeps top-to-bottom and Red sweeps left-to-right). But on the real matrix Green looks OK but Red has two opposite sweeping waves (one goes left-to-right and a second one goes right-to-left at the same time). Just in case here is a mapping code:
unction (pixelCount) {
//set zigzag to true if every other LED row travels in reverse
//if they are all straight across, set it to false
zigzag = false
//rotate a point (x, y), along a center (cx, cy), by an angle in degrees
cos = Math.cos(radians),
sin = Math.sin(radians),
return [nx, ny];
//sized (w, h), rotated by an angle, and offset by (sx, sy)
function panel(w, h, sx, sy, angle) {
var x, x2, y, p, map = []
for (y = 0; y < h; y++) {
for (x = 0; x < w; x++) {
if (zigzag && y % 2 == 1)
x2 = w - 1 - x
else
x2 = x
p = rotate((w-1)/2, (h-1)/2, x2, y, angle);
p[0] += sx
p[1] += sy
map.push(p)
return map;
//assemble one or more panels
var map = [];
map = map.concat(panel(16, 16, 0, 0, 0))
// map = map.concat(panel(8, 8, 8, 0, 0))
// map = map.concat(panel(8, 8, 0, 8, 0))
// map = map.concat(panel(8, 8, 8, 8, 0))
return map
And here is a test pattern code:
This pattern displays a sweep of color across a 2D pixel mapped display.
Red waves should travel left to right, and green waves from top to bottom.
var axis, t1
t1 = time(.1)
axis = t1 > .5
t1 *= 2
h = axis/3
v = wave((axis ? y : x)/2 - t1 + .5)
v = pow(v, 20)
hsv(h, 1, v)
Please advice what is wrong and how to fix this mapping problem/inconsistency?
