When I press attached momentary button to change patterns within PixelBlaze the whole display blanks out then restarts. Also, when a program change IS supposed to happen PB blanks off then restarts thereby never getting to the next program. 5 volts constant power. What gives?
Hi @FredEBear,
It sounds like a power supply issue. Like the supply can’t keep up with one of your patterns and is causing a reset. Try reducing the max brightness setting. If it still happens at 1% brightness, let us know!
