Hello!
I’m working on part two of my Pixelblaze & Lux Lavalier code tutorial, and trying to understand the ranges of values passed to and returned from the perlin function.
This code shows perlin returning numbers ranging from approx -0.5 to 0.5. Note that I’m using 0.01 for time just so the min and max vars that I’m watching (in the vars watch) update quicker.
export var min
export var max
t = time(.01)
noiseSpeed = t * 256 // noise inputs range from 0 to 256?
w = perlin(noiseSpeed, 0, 0, 0)
if (w < min) min = w
if (w > max) max = w
w = w + 0.5 // perlin returns values ranging from -0.5 to 0.5? adjust them to 0.0 to 1.0
h = x - w
hsv(h, 1, 1)
That makes a 1D rainbow (vertical bands) that moves horizontally back and forth irregularly.
Question one: It works, but seems to freeze in place periodically, not sure why?
Then, when I try to make a 2D noise rainbow with this code, I get a different range of return values from perlin (-0.885971 to 0.772766):
export var min
export var max
t = time(.01) // very slow sawtooth wave, every 458.752 seconds!
x2 = x + noiseSpeed
y2 = y
w = perlin(x2, y2, 0, 0)
w = (w * 1.1 + 1) / 2 // adjust the value to 0.0 to 1.0
h = w
hsv(h, 1, 1)
Question 2: what is the expected range of inputs and outputs, to and from the perlin noise function? Question 3: Why multiply noiseSpeed (ranging from 0.0 to 1.0) by 256? Wouldn’t that result in a range from 0 to 256? I would expect, if it’s a one byte range, that you’d multiply by 255 to get 0 to 255.
Any assistance would be greatly appreciated, thanks!
