New program: NaturalLightSync
Just wanted to share a program I made.
It smoothly changes the lights to match daylight color temperature. You can change the sunrise/sunset time and the max/min color temperatures. It’s called NaturalLightSync.
Hope it’s useful to someone!
Code below:
  ---Program to smoothly change lights to the color temperature of natural daylight---
  color temp conversion code borrowed from UtilityColorTemp program
Variables to set:
  -sunrise and sunset time (24hr clock)
  -maxTemp is the color temperture when the sun is highest (higher = blue-er); default is 5700
  -minTemp is the color temperature when the sun is lowest (lower = red-er); default is 2500
after sunset/before sunrise color temp will remain at mixTemp
var sunrise = 7;
var sunset = 20;
var maxTemp = (5700)/100;
var minTemp = (2500)/100;
var r,g,b;
function ctToRGB(ct){
    if( ct < 67 ){
        r = 1;
        g = 0.5313 * log(ct) - 1.2909;
        if( ct <= 19){
            b = 0;
            b = 0.0223 * ct - 0.5063;
        r = 38.309 * pow(ct,-0.886);
        g = 10.771 * pow(ct,-0.588);
        b = 1;
    r = clamp(r,0, 1);
    g = clamp(g,0, 1);
    b = clamp(b,0, 1);
export var ct;
export var timeOfDay;
  timeOfDay = clockHour() + clockMinute()/60 + clockSecond()/60/60;
  if ((timeOfDay >= sunrise) && (timeOfDay <= sunset)) {
    var peak = ((sunset-sunrise)/2)+sunrise
    var a = (minTemp-maxTemp)/pow((sunrise-peak), 2);
    ct = (a*pow((timeOfDay-peak),2))+maxTemp;
    ct = minTemp;
  ctToRGB(ct);
  rgb(r,g,b);
@domg,
Very cool! I can picture this being really nice in a lamp or room lighting.
Would you consider a sunset() sunrise() given lat and long?
