I’m still waiting for my pixelblaze to arrive, and have to start the whole journey… Learn to code from zero basically!
One question I have… If I’m playing patterns from a play list, is there a way just to “turn the brightness down”? I’m concerned my first project may be a bit too bright for people, in the given space… and editing the brightness of each pattern on the fly at an event seems a bit… Painful
Hi @Robinlawrie! You don’t have anything to worry about, there is a global brightness setting in the web interface that you can turn down and it will apply to all patterns.
Yes, values can be read from an external pot and applied to brightness, but it does require a few lines added to each pattern you want to dim this way.
See the example code for this in the ADC section of the new GPIO docs:
