overflo
September 27, 2024, 8:42pm
1
so i am building yet another dome.
this time its aluminum 2v dome like this: 2V Geodesic Dome Calculator » Domerama
most rods will have leds on them.
to make my life easier i wrote an opensCAD script to print me the coordinates of each pixel
you can find the script here:
This OpenSCAD script provides a function called "rod"rod() takes 3 arguments.an Array of X,Y,Z startcoordinatesan Array of X,Y,Z targetcoordinatesNumber of pixels on this AxisThe script can generate any structure that you can descibe with...
it consists of an array with joint locations and a function called rod() that takes 3 parameters
(array[x,y,z]) start, (array[x,y,z]) end, (int) pixelnum
it draws a line with pixnum spheres evenly distributed and prints each pixels location on the console so you can use it in the pixelblaze mapper.
i use it for a dome, but you can use it for ANY geometry that can be described in vectors.
of course its CC-0 so have fun and remix.
-flo
gorgeous! do you have video of patterns animating in your dome(s)?
overflo
September 16, 2026, 4:22pm
4
Not yet
But it will be built again in 2 weeks on top of a mountain.
Expect some videos later.
overflo
September 20, 2026, 6:57pm
5
mapping.json.scad (19.6 KB)
this is the .JSON file i use for the mapping.
i had to append a .scad to be able to upload it here as .json is forbidden
it looks good in preview and it should be correct.
the dome looks the way it is mapped having 5 distinct segments on an output expander board in the top center.
the animations for 3d-space are not displayed correctly, neither on the dome, nor on the browser preview.
what did i do wrong?
@wizard can you help me out here? pleeeeease have a look at the .json, it might be ovious to you.
It’s small so you can always paste it inline with
''' json
around it (except backquotes ` instead of ’ of course)
wizard
September 23, 2026, 11:56am
7
I changed it to allow json. Sorry it’s a approve list, not a deny list!
kijhbg
October 7, 2026, 5:10am
8
