Output Expander - Same pattern from each channel
Hey there!
Looking for some help creating a mapper function for my Pixelblaze and Output Expander setups.
Hard Coding 2 pixel lengths, I want to force it to play the same pattern on each channel at the same time.
3 art pieces each with their own PB and Output Expander.
Each OE has 2 LED strips attached of varying pixels: ie 570 pixels and 470 pixels
Originally I had them setup in the OE settings where both channels started on index 0 and I think that worked fine. However bringing them out for this year, I get an error with those settings.
With OE settings that don’t error, the pattern plays along the strips in sequence vs playing the same pattern simultaneously.
Any help here would be appreciated. I have tried a couple mapper code blocks I have written but haven’t been able to make it work so they line up.
Pic for reference
@wizard it looks like this may have been a change from a version update, where you can’t set 0 on all channels of a Output Expander.
Where can I find the easy changelog and download a specific version if I can’t get the mapper to work.
You’ll need something before v3.47, like 3.30
Thanks, I found a v3.40 DL in the threads the other day, downgraded all my PBs and I am back in business!
