Has anybody else seen this? It has happened to me a couple of times on the PB3 (never on the 2+), but this is the first time I’ve caught it in action and couldn’t write it off to me just forgetting to press “Save”.
Pixelblaze 3 standard, firmware 3.17, 591K available.
I was editing a pattern – call it “A” – then saved it and switched to another pattern to grab a chunk of code that I needed. When I switched back, pattern “A” loaded and ran with my latest edits and all slider controls functional. But the code area of the IDE was empty.
I then switched away from “A” again and looked at several other patterns in the IDE – all fine. When I switched back, “A” still runs, and still has no source code.
Tried exporting “A” – absolutely nothing happens when I press the export button. Other patterns still export fine.
What’d I do? Is there a way to recover the source (it’s actually no big deal if not – maybe 10 minutes of work. I save frequently to external .js files.)
These are computationally intensive patterns – sometimes the framerates go as low as 7 or 8 fps. The UI can be a little slow to respond when running one of these things. Could that cause problems with file I/O? Is there anything diagnostic I could look at to provide more information?
