Hi, apologies if I’m committing a beginner faux pas. Creating this as a separate Feature/Request thread in case it helps others.
Is there a known bug starting up on power on with a Mapped pattern in any case?
Short version: I have a PB powered thru an overhead light circuit, so I switch it on when I want to use it. Upon startup, if last set on a render2d or render3d displayed pattern, I get nothing until either picking a plain index-rendered pattern first, OR entering Mapping page and toggling Fill to Contain.
I have a very simple map, just a (gapped) octagon of linear WS2812’s defined as 2D coordinates:
[10.88313429, -15.98692339],
[11.34711512, -15.52294257],
[11.81109595, -15.05896174],
[12.27507677, -14.59498091],
[12.7390576, -14.13100008],
[13.20303843, -13.66701926],
[13.66701926, -13.20303843],
[14.13100008, -12.7390576],
[14.59498091, -12.27507677],
[15.05896174, -11.81109595],
[15.52294257, -11.34711512],
[15.98692339, -10.88313429],
[19, -3.608923885],
[19, -2.952755906],
[19, -2.296587927],
[19, -1.640419948],
[19, -0.984251969],
[19, -0.32808399],
[19, 0.32808399],
[19, 0.984251969],
[19, 1.640419948],
[19, 2.296587927],
[19, 2.952755906],
[19, 3.608923885],
[15.98692339, 10.88313429],
[15.52294257, 11.34711512],
[15.05896174, 11.81109595],
[14.59498091, 12.27507677],
[14.13100008, 12.7390576],
[13.66701926, 13.20303843],
[13.20303843, 13.66701926],
[12.7390576, 14.13100008],
[12.27507677, 14.59498091],
[11.81109595, 15.05896174],
[11.34711512, 15.52294257],
[10.88313429, 15.98692339],
[3.608923885, 19],
[2.952755906, 19],
[2.296587927, 19],
[1.640419948, 19],
[0.984251969, 19],
[0.32808399, 19],
[-0.32808399, 19],
[-0.984251969, 19],
[-1.640419948, 19],
[-2.296587927, 19],
[-2.952755906, 19],
[-3.608923885, 19],
[-10.88313429, 15.98692339],
[-11.34711512, 15.52294257],
[-11.81109595, 15.05896174],
[-12.27507677, 14.59498091],
[-12.7390576, 14.13100008],
[-13.20303843, 13.66701926],
[-13.66701926, 13.20303843],
[-14.13100008, 12.7390576],
[-14.59498091, 12.27507677],
[-15.05896174, 11.81109595],
[-15.52294257, 11.34711512],
[-15.98692339, 10.88313429],
[-19, 3.608923885],
[-19, 2.952755906],
[-19, 2.296587927],
[-19, 1.640419948],
[-19, 0.984251969],
[-19, 0.32808399],
[-19, -0.32808399],
[-19, -0.984251969],
[-19, -1.640419948],
[-19, -2.296587927],
[-19, -2.952755906],
[-19, -3.608923885],
[-15.98692339, -10.88313429],
[-15.52294257, -11.34711512],
[-15.05896174, -11.81109595],
[-14.59498091, -12.27507677],
[-14.13100008, -12.7390576],
[-13.66701926, -13.20303843],
[-13.20303843, -13.66701926],
[-12.7390576, -14.13100008],
[-12.27507677, -14.59498091],
[-11.81109595, -15.05896174],
[-11.34711512, -15.52294257],
[-10.88313429, -15.98692339],
[-3.608923885, -19],
[-2.952755906, -19],
[-2.296587927, -19],
[-1.640419948, -19],
[-0.984251969, -19],
[-0.32808399, -19],
[0.32808399, -19],
[0.984251969, -19],
[1.640419948, -19],
[2.296587927, -19],
[2.952755906, -19],
[3.608923885, -19],
When interface is first powered up after being last set on a render2d pattern, I see a warning in the interface:
I am on v3.40 which shows as valid current version.
If you need a code example I’m using the downloadable “Sun rays thru trees” with only some slider adjustments as last setting and it shows this behavior.
