Pigtail connectors for Output Expander
Hello,
I’ll be soldering the pin headers to the output expander soon, and looking for recommendations for a simple way to connect my light strings to the expander. I’d like it to be easily connected and removed.
What I had in mind is some sort of pigtail that I could connect to my xconnect pigtails as that’s how my light strings are terminated.
I could also wire the pin connectors directly to my xconnect pigtails if it’s a simple process. I don’t have steady hands so I’m trying to avoid delicate soldering situations. TIA,
Hey @SeaLaVie -
A lot of what you describe is exactly what I like the Pro Expander for. The pluggable screw terminals are easily connected and removed, making spares easy. They are faster than soldering or crimping and don’t require as steady a hand.
That said, once when a project felt like it had lots of time but not a lot of budget, I did strip and crimp the data wire from connectors similar to xConnect pigtails into tiny Dupont-style connectors (think like, 3-pin female servo connectors). With careful strain relief, it can work.
Thanks Jeff, I just realized since I’m using 12 volt I actually only need a two-pin connector since I will be using the ground and data but not the power. In any case I may buy a couple different connectors to see what works best.
That makes sense! This week, getting many holiday lights back up and working I’ve been reminded I have many wired in the same way with just data and ground! I was also reminded that apparently I’m not above an inline Wago and that they work fine :slight_smile: Might be another solution for doing less fine detail work with hands.
https://a.co/d/5T3UD1z
