I’m experiencing a bug I’ve never had before where upon giving power to my PixelBlaze (details below), it runs through a pattern as normal for roughly 3.5 seconds and then all of the LEDs turn off, and don’t come back on. Power cycling the PixelBlaze repeats this 3.5 seconds of success, followed by failure. When the LEDs are off, the PixelBlaze will still accept input / let me change the pattern / brightness / etc, but nothing happens to the LEDs.
Setup: PixelBlaze v3 updated to 3.51 with sensor expansion board attached but unused, connected to Micro-USB with a full 2.1a at the USB-A end, is connected to a strand of 353 25mm spacing pebble LEDs. Brightness is set to 20% maximum, and this was working fine for the first half hour or so of testing (no voltage drop, no flickering, no weirdness from that’s too many LEDs to drive from MicroUSB, everything was looking great).
I’ve tried using a pattern that’s EXTREMELY minimal power draw – the below snippet from the training tutorial which only has 3 LEDs lit at a time – and that didn’t change the observed behavior. I get the RGB three LEDs move along the line for a couple of seconds, the nothing.
In the web console, the status flashes from “connected” to “disconnected” and then back to “connected” when the LEDs turn off, indicating something is causing the PB to restart maybe?
I am confident I don’t have a short or wiring issue, because it WAS working for a half hour of testing prior to finding this issue, and when I swap over to a WLED board wired the exact same way I have lying around (I am running short on test PixelBlaze right now; I could take one out of another project) it works fine. And if it was a wiring issue (e.g. I swapped the ground and data lines or something) I wouldn’t get it working for the first 3.5 seconds. The PixelBlaze indicator LED stays a solid orange the whole time.
To prove I’m not just nuts, and because it’s a cool video, here’s what it was looking like BEFORE it stopped working for longer than 3.5 seconds at a time. I can’t think of anything I changed in between; I was just playing with patterns:
(This is a hat in the making)
red = green = blue = 0
leadPosition = time(0.08) * pixelCount
red = abs(leadPosition - index - 0) < 1
green = abs(leadPosition - index - 4) < 1
blue = abs(leadPosition - index - 8) < 1
rgb(red, green, blue)
@wizard this is probably a question for you?
