Pixelblaze on Wolfmix
Hey everyone,
I’m looking for someone who can help me put together a system to control Pixelblaze with a Wolfmix DMX controller.
Right now I’ve got a Pixelblaze V3, a Wolfmix W1 MK2, and a Raspberry Pi 5. I’m guessing I still need a DMX-to-Art-Net converter, plus whatever programming is needed to get everything talking properly.
It’s a bit of a challenge, but I’m sure there’s a genius in here who can figure it out! :grinning_face_with_smiling_eyes:
Hi and welcome!
You’re right – depending on exactly what you want to control and what the Wolfmix can output, you’ll need a DMX-to-Artnet or DMX-to-Ethernet converter box.
Once you get DMX data onto your network, take a look at my Art-Net->Pixelblaze control program on the github repo below and see if it does what you want. It’ll run easily on an rPI 5.
Things I know to watch out for:
  • Wi-Fi is fantastically unreliable for Art-Net in performance situations unless you control the router, and possibly get a high gain, directional antenna.
  • If you just want to control brightness/color/strobe rate and other relatively simple things via DMX, you won’t be sending much data over the air, and it will easier to build a reliable setup.
  • Sending lots of individual Art-Net pixel data over Wi-Fi can take some work to get right. And it may be really difficult or impossible in some situations. There are data encoding issues that I can explain further if you run into them, and signal strength and airtime contention issues that can cause trouble in crowded venues.
Thank you Zranger1.
Wolfmix sends dmx only. No Art-Net.So a bridge is needed. Do you suggest a dmx to Art-net or to Ethernet?
I just want to control brightness/color/strobe rate and other relatively simple things via DMX.
I use DMX/Artnet controller software with outboard MIDI control surfaces. Ethernet output is the default state. So I’m not absolutely certain about product recommendations for use w/dedicated DMX hardware. Something like this would do the job:
But I don’t have any great insight into specific brands or models. These boxes are all a bit expensive because they’re built for hard use. Like all touring gear, they’re physically really solid, and they also provide some electrical protection for your equipment.
There are ESP32/ESP8266 open source DIY solutions out there too, but unless you just want to experiment, it’s probably worth buying a pro box.
Just received the dmx-artnet node. Raspberry pi5 available too. Now how to proceed?
Zranger1 how to talk to you directly?
I’m traveling & mostly offline for the next few days. Will be back later this week. DM me here and I’ll answer as quickly as I can manage.
