I modified Text Scrolling Marquee pattern created by @jeff for my Message Board project.
Here is a modified code:
Scrolling text marquee 2D
This pattern animates ASCII characters scrolling across an LED matrix.
Demo: https://youtu.be/668eQjiqSRQ
The default settings work well with the $14 8x8 matrix sold here:
https://www.tindie.com/products/electromage/electromage-8x8-led-matrix/
Use the mapper to define how the matrix is wired (for example, zig-zag).
The 8x8 grid above works with the default "Matrix" example on the Mapper tab.
With no map and just a 1D strip, you can use this to light paint text:
https://photos.app.goo.gl/vU2BQsP6V84Zr6Df7
Author : Jeff Vyduna (https://ngnr.org)
Bugfixes : Zeb (https://forum.electromage.com/u/zeb)
// Max Message Buffer Size (N Charecters)
var bufferSize = 50
// Set of exported variables for the Remote Control application
// Character's Scrolling Speed (Ms)
// Minimum value is 25mS (max possible scrolling speed)
export var speed = 40
// Decimal Parameter to be displayed in the message
export var displayDecValue = 0
// Max number of Integer or Fraction digits
var nDigits = 5
// Hold Previous Decimal Value
var holdDecValue = displayDecValue
// Array for the converting "displayDecValue" variable
// into String
var convertArray = array(nDigits)
// Select Color Mode
// 0 - Each Character could be assigned individial color
// by putting Color Index in the messageCharRGB[] array
// 1 - Color for each Word cycles through the Collor Array
// (Assuming each Word is separated by Space character
// 2 - Color for each Message cycles through the Collor Array
export var selectColorMode = 1
// Initial Message Length (N Charecters)
// without injected Decimal Number
export var msgLengthInit = 0
// Actual Current Message Length (N Charecters)
export var messageLength = 0
// Holds actuall Scrolling Message
// By default Message Array is Zeroed
export var message = array(bufferSize)
// Holds Character Color Index
export var messageCharRGB = array(bufferSize)
// Color Control Parameters
// Number of LED Colors
var nColors = 3
// Max Number of predefined pixel colors
var colorArraySize = 8
// Predefined Pixel Colors Array
var pixelColors = array(colorArraySize)[nColors] =
// R G B
[0x00, 0x00, 0x00], // Black, Background Color
[0xff, 0x00, 0x00], // Red
[0xff, 0x64, 0x00], // Yellow
[0x00, 0xff, 0x00], // Green
[0x00, 0xff, 0xff], // Cyan
[0xff, 0x00, 0x7f], // Purple
[0x00, 0x00, 0xff], // Blue
[0xff, 0xff, 0xff] // White
ASCII Chart
32 48 0 65 A 74 J 83 S 97 a 106 j 115 s
33 ! 49 1 66 B 75 K 84 T 98 b 107 k 116 t
34 " 50 2 67 C 76 L 85 U 99 c 108 l 117 u
35 # 51 3 68 D 77 M 86 V 100 d 109 m 118 v
36 $ 52 4 69 E 78 N 87 W 101 e 110 n 119 w
37 % 53 5 70 F 79 O 88 X 102 f 111 o 120 x
38 & 54 6 71 G 80 P 89 Y 103 g 112 p 121 y
39 ' 55 7 72 H 81 Q 90 Z 104 h 113 q 122 z
40 ( 56 8 73 I 82 R 105 i 114 r
41 ) 57 9
42 * 58 : 91 [ 123 {
43 + 59 ; 92 \ 124 |
44 , 60 < 93 ] 125 }
45 - 61 = 94 ^ 126 ~
46 . 62 > 95 _
47 / 63 ? 96 `
64 @
// Define the font's character set bitmap.
// See "Font Implementation" below.
var charRows = 8 // Rows in a character. 1 array per row.
var charCols = 8 // Columns in a character. 1 bit per column.
// Max characters in the font. Must be a multiple of 4.
var fontCharCount = 128
var fontBitmap = array(charRows)
for (row = 0; row < charRows; row++)
fontBitmap[row] = array(fontCharCount / 4)
// Global 8x8bit array for storing and fetching characters from fontBitmap
var character = array(charRows)
// Define the 2D matrix display. If your matrix is different dimentions, change
// these to match or use a smaller matrixRows to scale your text height to fill.
var matrixRows = 8
var matrixCols = 64
var renderBuffer = array(matrixRows)
for (row = 0; row < matrixRows; row++)
renderBuffer[row] = array(matrixCols)
// ***** Frame Rate Timing *****
// Accumulates the ms between each beforeRender()
var timer = 0
// Calculate the ms between each left shift of the message across matrix columns
var colShiftPeriod
export function beforeRender(delta)
timer += delta
colShiftPeriod = speed
//colShiftPeriod = scrollSpeed(speed)
if (timer > colShiftPeriod)
timer -= colShiftPeriod
// Shift and load a new column every colShiftPeriod (mS)
loadNextCol()
messageLength = msgLengthInit
if ((0 == messageIdx)
&& (0 == colIndex)
&& (holdDecValue != displayDecValue))
convertDecimalValue(displayDecValue)
// ***** Display Pixel Buffer *****
export function render2D(index, x, y)
// y is in world units of 0...1 where (0,0) is the top-left and y is +↓
row = floor(y * matrixRows)
//row = clamp(floor(y * matrixRows), 0, matrixRows - 1)
// The column to render is like the row, but physical column 0 (the leftmost)
// starts bufferPointer columns into the renderBuffer.
col = (floor(x * matrixCols) + bufferPointer) % matrixCols
// Exr\traxt Pixel Color from Render Buffer
pixelRGB = renderBuffer[row][col]
// Display Pixel
unpackRGB(pixelRGB)
rgb((xR / 255), (xG / 255), (xB / 255))
// ***** Functions *****
// Pack 8-bit R, G, B values into
// single 16.16 Fixed Point RGB Variable
function packRGB(R, G, B)
RGB = ((R * 256) + G + (B / 256))
return RGB
// Unpack 8-bit RGB Values from
function unpackRGB(RGB)
xR = ((RGB / 256) & 0xFF)
xG = (RGB & 0xFF)
xB = (((RGB * 256) + 0.5) & 0xFF)
// Adjust Message Length according to the
// number of digits of Decimal Value
var adjustMessageLength = 0
// Convert Decimal Value to be displayed
// into ASCII Decimal String
function convertDecimalValue(displayDecValue)
// Add "-" character for negative values
if (displayDecValue < 0)
message[messageLength] = 45
adjustMessageLength++
x = floor(abs(displayDecValue))
convertInteger(x)
// Check Fraction Portion
if (frac(displayDecValue) != 0)
message[messageLength + adjustMessageLength] = 46
x = floor((frac(abs(displayDecValue)) * 100) + 0.5)
convertInteger(x)
// Convert Integer variable to string
function convertInteger(Int)
x = Int
// Convert Integer to String
for (i = 0; i < nDigits; i++)
convertArray[nDigits - 1 - i] = ((floor(x) % 10) + 48)
x = x /10
// Add String to message array
// and adjust message array length
skipZeroChar = true
if ((48 != convertArray[i]) || (false == skipZeroChar))
skipZeroChar = false
message[messageLength + adjustMessageLength] = convertArray[i]
// When we render the renderBuffer, we start by loading the leftmost column of
// the matrix from the `bufferPointer` column in the renderBuffer.
var bufferPointer = 0
E.g.: 8x8 matrix, rendering halfway through "AC": Right side of A, left of C
renderbuffer[r][c] Renders as:
`bufferPointer` == 4 means leftmost column is here, and wraps around to 3
col = 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7
row = 0 . . . 1 1 . . . 0 1 . . . . . . 1
1 . . 1 1 1 1 . . 1 1 1 . . . . 1 1
2 . 1 1 . . 1 1 . 2 . 1 1 . . 1 1 .
3 . 1 1 . . 1 1 . 3 . 1 1 . . 1 1 .
4 . 1 1 . 1 1 1 . 4 1 1 1 . . 1 1 .
4 . . 1 1 . 1 1 . 4 . 1 1 . . . 1 1
5 . . . 1 . 1 1 . 5 . 1 1 . . . . 1
7 . . . . . . . . 7 . . . . . . . .
This column will be replaced with the next column of "C",
↑ then we'll advance `bufferPointer`
Each element is a 16.16 fixed point number, so you could decide to pack HSV or
RGB info into each byte, but this example is monochrome so each element just
stores a 0 or 1, making rendering as simple as:
if (renderBuffer[row][col]) hsv(0,0,1)
// The next column of the overall message to load
var messageColPointer = 0
// Load the next column from `message` into `renderBuffer` at `bufferPointer`
function loadNextCol()
messageIdx = floor(messageColPointer / charCols)
charIndex = message[messageIdx]
// loads global `character` with ASCII charIndex
fetchCharacter(charIndex)
colIndex = messageColPointer % charCols
// Increment Color Index Counter at the beginning
// of every Word OR every Message
if (
((32 == charIndex) && (0 == colIndex) && (1 ==selectColorMode))
|| ((0 == messageIdx) && (0 == colIndex) && (2 ==selectColorMode))
incColorIdx()
bit = (((character[row] << colIndex) & 0b10000000) == 0b10000000)
if (0 == bit)
// Background Pixel Collor
// from Color Array
colorIndex = 0
else if (0 ==selectColorMode)
colorIndex = messageCharRGB[messageIdx]
else
colorIndex = colorIdxCounter
R = pixelColors[colorIndex][0]
G = pixelColors[colorIndex][1]
B = pixelColors[colorIndex][2]
RGB = packRGB(R, G, B)
renderBuffer[row][bufferPointer] = RGB
messageCols = (messageLength + adjustMessageLength) * charCols
bufferPointer = (bufferPointer + 1) % matrixCols
messageColPointer = (messageColPointer + 1) % messageCols
var colorIdxCounter = 1
function incColorIdx()
if (colorIdxCounter < (colorArraySize - 1))
colorIdxCounter++
else
colorIdxCounter = 1
Font Implementation
Pixelblaze currently supports up to 64 arrays with 2048 array elements.
To store a character set of 8x8 bit characters, we use 8 arrays,
one for each row.
Four 8-bit maps are packed into each 32 bit array element. This makes the
bitwise code a little hard to follow, but uses memory efficiently. The 8 most
significant bits are referred to as "bank 0"; the next eight bits just left of
the binary point are "bank 1", etc.
Here's the scheme used to store the font bitmap. A period is a zero.
ASCII character A B C D E
`charIndex` 65 66 67 68 69
array element [16] [16] [16] [16] [17]
bank 0 1 2 3 0
fontBitmap[0] ..11.... 111111.. ..1111.. 11111... 1111111.
fontBitmap[1] .1111... .11..11. .11..11. .11.11.. .11...1.
fontBitmap[2] 11..11.. .11..11. 11...... .11..11. .11.1...
fontBitmap[3] 11..11.. .11111.. 11...... .11..11. .1111...
fontBitmap[4] 111111.. .11..11. 11...... .11..11. .11.1...
fontBitmap[5] 11..11.. .11..11. .11..11. .11.11.. .11...1.
fontBitmap[6] 11..11.. 111111.. ..1111.. 11111... 1111111.
fontBitmap[7] ........ ........ ........ ........ ........
charIndex 0..31 (traditionally the ASCII control characters) are left
blank for user-defined custom characters.
Font and character functions
The storeCharacter functions take the character index (< `fontCharCount`) and
8 rows of 8 bits. Each row is a byte representing 8 bits of on/off bitmap data
to become the pixels of a character. Therefore, this implementation is
currently tightly coupled to 8-bit wide characters.
At character index `charIndex`, store 8 bytes of row data specified as
sequential arguments r0-r7. This allows us to easily use the public domain
font specified as comma-delimited hex bytes at:
https://github.com/rene-d/fontino/blob/master/font8x8_ib8x8u.ino
function storeCharacter(charIndex, r0, r1, r2, r3, r4, r5, r6, r7)
element = floor(charIndex / 4)
bank = charIndex % 4
packByte(0, element, bank, r0)
packByte(1, element, bank, r1)
packByte(2, element, bank, r2)
packByte(3, element, bank, r3)
packByte(4, element, bank, r4)
packByte(5, element, bank, r5)
packByte(6, element, bank, r6)
packByte(7, element, bank, r7)
This alternate style stores the character using the 8 row global array named
`character`. It could be useful for storing sprites after transformations to
create animations.
function storeCharacter2(charIndex)
for (var row = 0; row < charRows; row++)
packByte(row, element, bank, character[row])
// Loads the global `character` from the specified charIndex
function fetchCharacter(charIndex)
character[row] = unpackByte(row, element, bank)
For a given row of a font's pixel data (fontBitmap[row]), there's a
(fontCharCount / 4) element long array that holds 32 bits per array element.
Thinking of each array element as a 4-byte word, the "bank" (0..3) specifies
which set of 8 bits we're storing for a particular character. Characters are
referred to by their charIndex (ASCII number), so:
bank 0 in elements 0, 1, & 2 store the data for characters 0, 4, 8, etc;
Bank 1 in elements 0, 1, & 2 store the data for characters 1, 5, 9, etc.
The method below is used because the bitwise operators only work on
the top 16 bits.
var byteHolder = array(4)
function packByte(row, element, bank, byte)
original = fontBitmap[row][element]
// Load a 4-element array with the individual bytes in this 32 bit 'word'
for (_bank = 0; _bank < 4; _bank++)
byteHolder[_bank] = (((original << (_bank * 8)) & 0xFF00) >> 8) & 0xFF
// Override the 8 bits we're trying to store
byteHolder[bank] = byte
// Reassemble the 32 bit 'word'
fontBitmap[row][element] = (byteHolder[0] << 8)
+ byteHolder[1]
+ (byteHolder[2] >> 8)
+ (byteHolder[3] >> 16)
// Inverse of packByte()
function unpackByte(row, element, bank)
word = fontBitmap[row][element]
if (bank > 1)
byte = (word << (8 * (bank - 1)))
else if (bank == 0)
byte = (word >> 8)
else
byte = word
// Zero out all but the 8 bits left of the binary point
return (byte & 0xFF)
Font Data
Public domain, courtesy of
storeCharacter( 32, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x20 (space)
storeCharacter( 33, 0x30, 0x78, 0x78, 0x30, 0x30, 0x00, 0x30, 0x00) // 0x21 (exclam)
storeCharacter( 34, 0x6c, 0x6c, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x22 (quotedbl)
storeCharacter( 35, 0x6c, 0x6c, 0xfe, 0x6c, 0xfe, 0x6c, 0x6c, 0x00) // 0x23 (numbersign)
storeCharacter( 36, 0x30, 0x7c, 0xc0, 0x78, 0x0c, 0xf8, 0x30, 0x00) // 0x24 (dollar)
storeCharacter( 37, 0x00, 0xc6, 0xcc, 0x18, 0x30, 0x66, 0xc6, 0x00) // 0x25 (percent)
storeCharacter( 38, 0x38, 0x6c, 0x38, 0x76, 0xdc, 0xcc, 0x76, 0x00) // 0x26 (ampersand)
storeCharacter( 39, 0x60, 0x60, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x27 (quotesingle)
storeCharacter( 40, 0x18, 0x30, 0x60, 0x60, 0x60, 0x30, 0x18, 0x00) // 0x28 (parenleft)
storeCharacter( 41, 0x60, 0x30, 0x18, 0x18, 0x18, 0x30, 0x60, 0x00) // 0x29 (parenright)
storeCharacter( 42, 0x00, 0x66, 0x3c, 0xff, 0x3c, 0x66, 0x00, 0x00) // 0x2a (asterisk)
storeCharacter( 43, 0x00, 0x30, 0x30, 0xfc, 0x30, 0x30, 0x00, 0x00) // 0x2b (plus)
storeCharacter( 44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x60) // 0x2c (comma)
storeCharacter( 45, 0x00, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x00, 0x00) // 0x2d (hyphen)
storeCharacter( 46, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00) // 0x2e (period)
storeCharacter( 47, 0x06, 0x0c, 0x18, 0x30, 0x60, 0xc0, 0x80, 0x00) // 0x2f (slash)
storeCharacter( 48, 0x7c, 0xc6, 0xce, 0xde, 0xf6, 0xe6, 0x7c, 0x00) // 0x30 (zero)
storeCharacter( 49, 0x30, 0x70, 0x30, 0x30, 0x30, 0x30, 0xfc, 0x00) // 0x31 (one)
storeCharacter( 50, 0x78, 0xcc, 0x0c, 0x38, 0x60, 0xc4, 0xfc, 0x00) // 0x32 (two)
storeCharacter( 51, 0x78, 0xcc, 0x0c, 0x38, 0x0c, 0xcc, 0x78, 0x00) // 0x33 (three)
storeCharacter( 52, 0x1c, 0x3c, 0x6c, 0xcc, 0xfe, 0x0c, 0x1e, 0x00) // 0x34 (four)
storeCharacter( 53, 0xfc, 0xc0, 0xf8, 0x0c, 0x0c, 0xcc, 0x78, 0x00) // 0x35 (five)
storeCharacter( 54, 0x38, 0x60, 0xc0, 0xf8, 0xcc, 0xcc, 0x78, 0x00) // 0x36 (six)
storeCharacter( 55, 0xfc, 0xcc, 0x0c, 0x18, 0x30, 0x30, 0x30, 0x00) // 0x37 (seven)
storeCharacter( 56, 0x78, 0xcc, 0xcc, 0x78, 0xcc, 0xcc, 0x78, 0x00) // 0x38 (eight)
storeCharacter( 57, 0x78, 0xcc, 0xcc, 0x7c, 0x0c, 0x18, 0x70, 0x00) // 0x39 (nine)
storeCharacter( 58, 0x00, 0x30, 0x30, 0x00, 0x00, 0x30, 0x30, 0x00) // 0x3a (colon)
storeCharacter( 59, 0x00, 0x30, 0x30, 0x00, 0x30, 0x30, 0x60, 0x00) // 0x3b (semicolon)
storeCharacter( 60, 0x18, 0x30, 0x60, 0xc0, 0x60, 0x30, 0x18, 0x00) // 0x3c (less)
storeCharacter( 61, 0x00, 0x00, 0xfc, 0x00, 0x00, 0xfc, 0x00, 0x00) // 0x3d (equal)
storeCharacter( 62, 0x60, 0x30, 0x18, 0x0c, 0x18, 0x30, 0x60, 0x00) // 0x3e (greater)
storeCharacter( 63, 0x78, 0xcc, 0x0c, 0x18, 0x30, 0x00, 0x30, 0x00) // 0x3f (question)
storeCharacter( 64, 0x7c, 0xc6, 0xde, 0xde, 0xde, 0xc0, 0x78, 0x00) // 0x40 (at)
storeCharacter( 65, 0x30, 0x78, 0xcc, 0xcc, 0xfc, 0xcc, 0xcc, 0x00) // 0x41 (A)
storeCharacter( 66, 0xfc, 0x66, 0x66, 0x7c, 0x66, 0x66, 0xfc, 0x00) // 0x42 (B)
storeCharacter( 67, 0x3c, 0x66, 0xc0, 0xc0, 0xc0, 0x66, 0x3c, 0x00) // 0x43 (C)
storeCharacter( 68, 0xf8, 0x6c, 0x66, 0x66, 0x66, 0x6c, 0xf8, 0x00) // 0x44 (D)
storeCharacter( 69, 0xfe, 0x62, 0x68, 0x78, 0x68, 0x62, 0xfe, 0x00) // 0x45 (E)
storeCharacter( 70, 0xfe, 0x62, 0x68, 0x78, 0x68, 0x60, 0xf0, 0x00) // 0x46 (F)
storeCharacter( 71, 0x3c, 0x66, 0xc0, 0xc0, 0xce, 0x66, 0x3e, 0x00) // 0x47 (G)
storeCharacter( 72, 0xcc, 0xcc, 0xcc, 0xfc, 0xcc, 0xcc, 0xcc, 0x00) // 0x48 (H)
storeCharacter( 73, 0x78, 0x30, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x49 (I)
storeCharacter( 74, 0x1e, 0x0c, 0x0c, 0x0c, 0xcc, 0xcc, 0x78, 0x00) // 0x4a (J)
storeCharacter( 75, 0xe6, 0x66, 0x6c, 0x78, 0x6c, 0x66, 0xe6, 0x00) // 0x4b (K)
storeCharacter( 76, 0xf0, 0x60, 0x60, 0x60, 0x62, 0x66, 0xfe, 0x00) // 0x4c (L)
storeCharacter( 77, 0xc6, 0xee, 0xfe, 0xfe, 0xd6, 0xc6, 0xc6, 0x00) // 0x4d (M)
storeCharacter( 78, 0xc6, 0xe6, 0xf6, 0xde, 0xce, 0xc6, 0xc6, 0x00) // 0x4e (N)
storeCharacter( 79, 0x38, 0x6c, 0xc6, 0xc6, 0xc6, 0x6c, 0x38, 0x00) // 0x4f (O)
storeCharacter( 80, 0xfc, 0x66, 0x66, 0x7c, 0x60, 0x60, 0xf0, 0x00) // 0x50 (P)
storeCharacter( 81, 0x78, 0xcc, 0xcc, 0xcc, 0xdc, 0x78, 0x1c, 0x00) // 0x51 (Q)
storeCharacter( 82, 0xfc, 0x66, 0x66, 0x7c, 0x6c, 0x66, 0xe6, 0x00) // 0x52 (R)
storeCharacter( 83, 0x78, 0xcc, 0xe0, 0x70, 0x1c, 0xcc, 0x78, 0x00) // 0x53 (S)
storeCharacter( 84, 0xfc, 0xb4, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x54 (T)
storeCharacter( 85, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xfc, 0x00) // 0x55 (U)
storeCharacter( 86, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x00) // 0x56 (V)
storeCharacter( 87, 0xc6, 0xc6, 0xc6, 0xd6, 0xfe, 0xee, 0xc6, 0x00) // 0x57 (W)
storeCharacter( 88, 0xc6, 0xc6, 0x6c, 0x38, 0x38, 0x6c, 0xc6, 0x00) // 0x58 (X)
storeCharacter( 89, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x30, 0x78, 0x00) // 0x59 (Y)
storeCharacter( 90, 0xfe, 0xc6, 0x8c, 0x18, 0x32, 0x66, 0xfe, 0x00) // 0x5a (Z)
storeCharacter( 91, 0x78, 0x60, 0x60, 0x60, 0x60, 0x60, 0x78, 0x00) // 0x5b (bracketleft)
storeCharacter( 92, 0xc0, 0x60, 0x30, 0x18, 0x0c, 0x06, 0x02, 0x00) // 0x5c (backslash)
storeCharacter( 93, 0x78, 0x18, 0x18, 0x18, 0x18, 0x18, 0x78, 0x00) // 0x5d (bracketright)
storeCharacter( 94, 0x10, 0x38, 0x6c, 0xc6, 0x00, 0x00, 0x00, 0x00) // 0x5e (asciicircum)
storeCharacter( 95, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff) // 0x5f (underscore)
storeCharacter( 96, 0x30, 0x30, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x60 (grave)
storeCharacter( 97, 0x00, 0x00, 0x78, 0x0c, 0x7c, 0xcc, 0x76, 0x00) // 0x61 (a)
storeCharacter( 98, 0xe0, 0x60, 0x60, 0x7c, 0x66, 0x66, 0xdc, 0x00) // 0x62 (b)
storeCharacter( 99, 0x00, 0x00, 0x78, 0xcc, 0xc0, 0xcc, 0x78, 0x00) // 0x63 (c)
storeCharacter(100, 0x1c, 0x0c, 0x0c, 0x7c, 0xcc, 0xcc, 0x76, 0x00) // 0x64 (d)
storeCharacter(101, 0x00, 0x00, 0x78, 0xcc, 0xfc, 0xc0, 0x78, 0x00) // 0x65 (e)
storeCharacter(102, 0x38, 0x6c, 0x60, 0xf0, 0x60, 0x60, 0xf0, 0x00) // 0x66 (f)
storeCharacter(103, 0x00, 0x00, 0x76, 0xcc, 0xcc, 0x7c, 0x0c, 0xf8) // 0x67 (g)
storeCharacter(104, 0xe0, 0x60, 0x6c, 0x76, 0x66, 0x66, 0xe6, 0x00) // 0x68 (h)
storeCharacter(105, 0x30, 0x00, 0x70, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x69 (i)
storeCharacter(106, 0x0c, 0x00, 0x0c, 0x0c, 0x0c, 0xcc, 0xcc, 0x78) // 0x6a (j)
storeCharacter(107, 0xe0, 0x60, 0x66, 0x6c, 0x78, 0x6c, 0xe6, 0x00) // 0x6b (k)
storeCharacter(108, 0x70, 0x30, 0x30, 0x30, 0x30, 0x30, 0x78, 0x00) // 0x6c (l)
storeCharacter(109, 0x00, 0x00, 0xcc, 0xfe, 0xfe, 0xd6, 0xc6, 0x00) // 0x6d (m)
storeCharacter(110, 0x00, 0x00, 0xf8, 0xcc, 0xcc, 0xcc, 0xcc, 0x00) // 0x6e (n)
storeCharacter(111, 0x00, 0x00, 0x78, 0xcc, 0xcc, 0xcc, 0x78, 0x00) // 0x6f (o)
storeCharacter(112, 0x00, 0x00, 0xdc, 0x66, 0x66, 0x7c, 0x60, 0xf0) // 0x70 (p)
storeCharacter(113, 0x00, 0x00, 0x76, 0xcc, 0xcc, 0x7c, 0x0c, 0x1e) // 0x71 (q)
storeCharacter(114, 0x00, 0x00, 0xdc, 0x76, 0x66, 0x60, 0xf0, 0x00) // 0x72 (r)
storeCharacter(115, 0x00, 0x00, 0x7c, 0xc0, 0x78, 0x0c, 0xf8, 0x00) // 0x73 (s)
storeCharacter(116, 0x10, 0x30, 0x7c, 0x30, 0x30, 0x34, 0x18, 0x00) // 0x74 (t)
storeCharacter(117, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0xcc, 0x76, 0x00) // 0x75 (u)
storeCharacter(118, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0x78, 0x30, 0x00) // 0x76 (v)
storeCharacter(119, 0x00, 0x00, 0xc6, 0xd6, 0xfe, 0xfe, 0x6c, 0x00) // 0x77 (w)
storeCharacter(120, 0x00, 0x00, 0xc6, 0x6c, 0x38, 0x6c, 0xc6, 0x00) // 0x78 (x)
storeCharacter(121, 0x00, 0x00, 0xcc, 0xcc, 0xcc, 0x7c, 0x0c, 0xf8) // 0x79 (y)
storeCharacter(122, 0x00, 0x00, 0xfc, 0x98, 0x30, 0x64, 0xfc, 0x00) // 0x7a (z)
storeCharacter(123, 0x1c, 0x30, 0x30, 0xe0, 0x30, 0x30, 0x1c, 0x00) // 0x7b (braceleft)
storeCharacter(124, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0x00) // 0x7c (bar)
storeCharacter(125, 0xe0, 0x30, 0x30, 0x1c, 0x30, 0x30, 0xe0, 0x00) // 0x7d (braceright)
storeCharacter(126, 0x76, 0xdc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00) // 0x7e (asciitilde)
// Other user-defined custom characters
// ASCII 63 is the question mark - here's an alternative from the
// Sinclair ZX81 font, stored in custom slot 30
storeCharacter(30,
0b00000000,
0b00111100,
0b01000010,
0b00000100,
0b00001000,
0b00000000,
0b00001000,
0b00000000
// This demonstrates copying the character, altering it, then storing it in the
// next slot. You could use this for programmatic animation.
fetchCharacter(30)
character[7] = 0b00001000
storeCharacter2(31)
I got everything working, including dynamic injecting Decimal Number in a predefined message.
Code has few exported variables for the remote control capability via WebSocket API.
If I restart a pattern and send all control variables everyting works as expected.
I can modify/update all exported variables on a fly and see the updated value reflected in
the Vars Watch window.
One variable which is “msgLengthInit” on line 65 gives me a big trouble.
I can see its value and a value for the related variable “messageLength” on line 68 updated
but the pattern behavior is like var messageLength retains its previous value.
When I restart a pattern everything becomes normal.
All other exported variables do not exhibit this problem.
Please help me to debug, understand and fix this problem.
UPDATE.
After recycling power to the PB everything became normal.
Good news - code is wirking as expected.
Bad news - again things magically fixed itself.
Similar behavior I observed when I was changing mapping code on a fly.
Until I recycled PB power mapping code did not work.
