From the docs:
- Closures aren’t supported, so any function defined in another function won’t have access to parameters or local variables. It can still access globals or its own parameters.
This is a little different from normal JS, and it most commonly catches me when using the array functions.
Array functions can access globals. Say we wanted to normalize all elements of an array by finding the max value and dividing all elements by that max.
var maxVal
function normalize(arr) {
maxVal = arr.reduce((acc, v) => max(acc, v), arr[0])
arr.mutate(v => v / maxVal)
Docs again:
Explicitly declared variables will either be global or local depending on where they are declared. Local variables declared using
var
inside a function are visible inside that function.
The following works the same, because without var
preceding maxVal
inside the function, it defines maxVal
as a global:
// var maxVal // Notice the only change is that this line is now commented out. Works the same!
But back to this again:
Array functions commonly pass functions defined using arrow function notation (=>
), and again: functions within functions cannot access locals. This code can’t see maxVal because the var
defining it inside normalize()
means it’s a local variable.
// Won't work
var maxVal = arr.reduce((acc, v) => max(acc, v), arr[0])
arr.mutate(v => v / maxVal) // Undefined symbol maxVal
I hope I stumble on my own post here in 3 months when I forget why my pithy lambdas couldn’t see a variable
