Hi,
I’m trying to figure out a setup for an art car for Burning Man. I have a few questions.
- I’m planing on adding LEDs to the inside and bottom of the car. The total number of LEDs is 626. How many amps should I plan on using? I was reading I should plan on the RGB leds using 0.06amps per pixel. I’m also thinking of using SK6812 RGBW stips. How many amps should I plan for with a RGBW SK6812 strip vs RGB WS2812B?
- Is it better to use two smaller power supplies (one at each end of the strip) vs using a more powerful power supply at one end?
- Also any benefit to splitting up the LEDs into two separate parts? There would be separate power supplies and pixelblazes. One would be a strip with a total 336 LEDS (inside of the car) and another strip of 290 LEDS (bottom of the car). I am thinking of running two separate patterns and thought spliting them up would make it easier to setup.
- I might be running the strips off of a battery vs using an inverter. Assuming I’m using several power supplies could I attach multiple of these: DC Voltage Regulator Buck Converter DC 12V 24V to DC 5V 30A to provide the correct amount of amps?
Thanks
