Raising only one LED
172/5000
Hello,
can I ask for advice:
  1. How can I turn on one particular LED, such as ice number 10?
  2. Can I find out which LEDs are currently being displayed?
THX
  1. turning on a single LED
    Inside render(index)
    // Only turn on led #10
    if(index == 9) {
    hsv(h,s,v)
  2. the function render(index) has a parameter index which tells you which led is being used for that iteration of the function. You can add a watch for index to see which one is currently being used, but the watch would update very quickly. Can you give more info on your second question?
Hello,
one more help I need.
if I use x = random (pixelCount) randomly, I get a number like “56.454436”, but how can I only get integers, that is, “56”?
THX
You can use floor or ceil functions depending on if you want the closest low or high number.
