I have been working with my ninth PB and have run into a problem. The controller started behaving erratically and several attempts to reset and start over have failed. The initial weirdness was that it was ignoring the brightness settings and just going whole hog on intensity which caused the input voltage to droop. I am using an HP current limited power supply set to 1 amp and driving 512 WS1812B lights.
I’m getting a message that says “The controller has restarted from repeated errors and has loaded fail-safe settings. Proceed with caution- using this interface may persist fail-safe settings”.
It sounds pretty dire and I am clueless as to what caution means in this case. Is at a bad PB or am I being bad?
I am running the display at low current while getting things going. Typically I was drawing under 700mA.
I am interested in how to check storage. I have not done that before.
Another thing I am curious about is the two settings for LED intensity. One is in the settings and is a percentage. The other is a slider on the patterns page. Do they interact or what?
If average was 700ma with LEDs (which is still pretty crazy for that many LEDs), you could see a few millisecond duration spikes up to 500ma higher during radio activity, during which your power supply would cut the power and the chip can brown out.
