Maybe this is a dumb question, but if we’re using RGBW LEDs (either from you directly or third party) is there anything special we have to do to reap the benefits of the truer white colors if we select the right type of LEDs in the settings of the PixelBlaze? In other words, does the settings + the LEDs correctly use the white LED within each pixel when the colors passed in the code are white?
Pixelblaze supports RGBW LEDs and automatically trades R+G+B values for white. Most RGBW LEDs I’ve tested balance their white element likewise so that the white element has roughly the same brightness as a R+G+B mixed white would.
Thanks for putting these out! For a while it was impossible to find SK9822 matrices on rigid backing. I have a few of these from Electromage and a few from other manufacturers, and I appreciate that the Electromage ones are on thicker PCBs and are placed precisely by machine.
