Rgbw strip not doing the w when using rgb function
I have a pixelblaze v3 and am using three different BTF SK6812 60led RGBW strips…
one for natural white, one warm white and one cool white… I want to test the W to see which white works best for me…
I have the pixelblaze set for ws2812 leds, 60 of them and I try different color orders and the only time the W illuminates is with RGB… not RGBW…
code running is
rgb(1.0,1.0,1.0)
Fascinating…
code
hsv(1.0,0.0,1.0)
Works as expected with only the W being used (for white) in rgbw
@wizard Is this a known issue that rgbw strips only work (or more correctly the white led) with hsv and not rgb functions?
@devoh ,
Right, RGBW support is missing when using rgb() - I’ll get that in the next update.
I feel like this is a dumb question, but will that update also apply to GRBW?
Non-official, non @wizard answer, but I can say with almost 100% assurance, yes, it will – pretty sure the Pixelblaze only reorders colors as its sends data to the LEDs.
And in any case the ‘W’ calculation just looks at the difference between R,G, and B color values to figure out how much white ought to be present. The closer together they are, the more white. Changing color order doesn’t affect this calculation at all.
Yep, RGBW/GRBW both.
I have this working, along a few more changes in the release. The rgb() function also didn’t support HDR e.g. with APA102/SK9822 LEDs, but that is getting fixed as well! Just a bit more to polish up on the release, and port back to V2.x.
Ohhhhh that explains a few things. If I have a chance to port in rgb2hsv, I’ll compare my RGB output with hsv(rgb2hsv). Otherwise I’ll wait for the update.
